Brush hog advice
/ Brush hog advice
Steve...That's great your getting your apprentices to help you on your cutter.
Lol, yup. There is a warning in the Bush hog owner's manual regarding child labor laws, so forget what you saw:laughing:
/ Brush hog advice
Here is Part 6:
[ame=http://www.youtube.com/watch?v=lnigpDrJCZA]Bush hog 305 Part 6 - YouTube[/ame]
/ Brush hog advice
The new wheel assemblly came in today. If this head cold gets better, I might be back to work on the cutter tommorow.
/ Brush hog advice #124
Can't wait to see the finished product! :thumbsup:
/ Brush hog advice #125
ditto that!
/ Brush hog advice
Got a lot done over the weekend, here is Part 7, and Part 8 will follow shortly!
[ame=http://www.youtube.com/watch?v=B9vfi572q44]Bush hog 305 part 7 - YouTube[/ame]
/ Brush hog advice
Part 8:
[ame=http://www.youtube.com/watch?v=zNWiEHF1Rjo]Bush Hog 305 Part 8 - YouTube[/ame]
/ Brush hog advice
ditto that!
Did you guys get a chance to check out the last 2 videos I added?
What do you think about the PTO shield? Should I let it free spin, or should I add small chains to keep it from rotating??
Thanks,
Steve W.
/ Brush hog advice #129
Thanks,
Steve W.
I don't keep the chains on mine, it wears out the bearings on the shielding. Just keep it greased and loose so if someone does come in contact with it the shielding can stop independent of the shaft.
/ Brush hog advice #130
I don't know if I ever shared this with you or if you've seen it in another thread but I had a Bushhog 306 that was much like yours until I made a few slight modifications. :) Those old mowers like you've got are as tough as nails!
I cut a few trees 5" in diameter with this one...
/ Brush hog advice
That's what I was thinking. At $23 a set, those plastic bearings are kind of overpriced IMO.
Steve.
/ Brush hog advice
Yup, that elevated gear box on it's own frame is the dead giveaway! Good looking mower, I like that push bar you rigged up, must be handy when backing the mower over bigger stuff.
/ Brush hog advice #133
stevewatr said:
Finally finished editing the video of me testing out the bush hog, almost busted my radiator, but other than that, it worked well.
Video Link: http://www.youtube.com/watch?v=mMH2qBq5Lek
The internet is slow here tonight for some reason so I couldn't finish it, but from what I saw it looked like it was doing good.
One thing I noticed though was the chains in your front guard flipping up on top of the deck. You can take a small cable and run through the chain links about half way down the length of the chain to stop that if needed.
/ Brush hog advice
Yeah, I goofed and forgot Part 9, so I pulled Part 10 off you tube, and will post 9 first. The chains are a little too long. when I first started cutting, the blade tips were hitting the chains, as the brush pushed the chains back.
/ Brush hog advice #135
I quit using chain curtains a long time ago. Down here in the South it's a lot less dusty in the summertime with rubber belting instead. :)
/ Brush hog advice
I'm wishing I knew how dusty it gets, then I would have done the same. Another thing I learned is I may want to start wearing a dust mask. Stuff I'm breathing in cannot be good for allergies, or just in general. Also makes me wonder about when I'm mowing areas with poison ivy :confused:
/ Brush hog advice
Okay, here is Part 9 that I was missing. it shows the issue I had with the tail wheel assemblly:
[ame=http://www.youtube.com/watch?v=mvpVzwiALLo]Bush hog 305 Part 9 - YouTube[/ame]
/ Brush hog advice #138
That could be a problem if your very allergic. I work for the U.S. Forest Service through the summers during my college years. One day a crew responded to a wildfire and had to send a guy to the hospital because the fire was burning through a lot of poison ivy and he had a major reaction from the smoke, it was down in his lungs and everywhere.
/ Brush hog advice #139
Steve...it sounds like your losing your bush hog enthusiasm.:( It's the price you pay when you get a fixer upper.
/ Brush hog advice
Lol, naaaaah, just wait untill I post Part 10, then you'll see I'm giddy as a school girl :ashamed:
2024 MAHINDRA ROXOR OFF ROAD UTV (A64280)
2024 MAHINDRA...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2014 Ford Transit Connect Passenger Van (A61573)
2014 Ford Transit...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
iDrive TDS-2010H...
HYD GRAVITY FED CAR LIFT (A64281)
HYD GRAVITY FED...
