Brush hog advice
/ Brush hog advice #101
How hard is it to weld with an oxygen/acetelyne or propolyne torch?
Because I wish I had a torch to help me scrap my backhoe. Some pins are stuck, and some pieces are too big to move, and need to be cut up.
you can only weld with oxy/acetelyne torch. Not propane. But you can braze with a propane torch.
/ Brush hog advice #102
LD1...steve did not mean propane. It is polypropylene.
Here is an article describing the difference between propylene and acetylene.
Oxy-Fuel Cutting with Propylene
The shop worked at switched over to propylene years ago. There is a learning curve but it does run much cleaner.:confused2:
/ Brush hog advice #103
It appears I mis-read his post:confused2:
But thanks for the link. It looks like you still cannot gas weld with it though. Leaving only oxy/acet for that.
/ Brush hog advice
Yup, I really slaughtered the spelling on that one:ashamed:
Good link. I see why guys say it cuts faster.
/ Brush hog advice
That's just stupid IMO.
I guess they figure it makes the tractor more desireable to a potential buyer.
Problem is, if the buyer has no interest in a Brush hog, or post hole digger, they will attach little value to them when formulating an offer to buy.
Another reason might be the seller is still working the tractor while it is for sale, and if he sells the impliments first, would have nothing to use. One seller told me "spring was coming" and that if he did not sell the package by then, he'd use it then.
There are occasions where one might not want to sell any impliments untill the tractor is sold. I have a few impliments made for my Earthmaster, and although the tractor is rare, I've seen genuine impliments for them go for more $$ than the tractor! If I were selling mine, I'd would not sell the impliments untill I had the tractor sold, and the buyer would get first shot at the impliments.
Gotta get back to trying to get this blade carrier off! :mad:
Steve W.
/ Brush hog advice #107
I dont think it is stupid.
Sure, the seller probabally knows he will get less $$ total, but less hassle in return.
If he sells JUST the tractor and then tries to sell the BH, a potential buyer cannot see it operate, and he does not have a way to load it. So a buyer would have to go to the trouble of bringing his own tractor. And then the buyer knows the seller probabally wont negotiate much, since you went to the trouble of bringing a tractor to test and load. Again, just a lot of hassle.
And if he sells the bushhog first, the tractor is probabally usless to him.
Odds are, it is probabally just a cheap BH to sweeten the deal on the tractor.
The reasons are many why someone doesnt seperate equipment. To each his own. Both methods of selling work, so it obviously isnt too stupid.
/ Brush hog advice #108
IMHO.. gas welding is too time consuming and costly, when an arc welder is faster and easier to use.
I use a O/A torch for cutting.
propane? that's good to solder or cook hotdogs...
soundguy
/ Brush hog advice #109
soundguy
I have to agree with Soundguy, I always use my ARC or even my little mig to weld, my O/A is 90% for heating stuff to take it apart and the other 10% to cut stuff that is too think for the plasma.
/ Brush hog advice #110
yep.. oa for cutting heatin, and lighting grease fires in hubs cutting races out... :)
/ Brush hog advice #111
I disagree.
O/A is like a poor mans TIG:thumbsup: A $250 set of torches and a $250 stick and you can weld steel ranging from sheet metal to thick stuff.
Obviously, if given a choice, I would prefer TIG for 16-20GA steel. But my second choice would be O/A.
Arc welding IS faster and easier for most stuff. But not for thin stuff IMO. And a $2000+ TIG set-up is a little overkill IMO for a home hobbiest...especially if he already has a torch.
/ Brush hog advice #112
Man, and to think I was bad about going off on a tangent, lol. First brush hogs, then finish mowers, to nail clipping a field, and now on to welding and cutting and which one is best for that.
As far as the O/P and his neighbor, maybe he LIKES you to come over with projects to work on? I have a good friend that comes over and we go at all kinds of different projects. Some small, some way too big, but we always have a good time ('cept that one time I dropped a piece of channel on my foot, but steel toed shoes have helped that)
He might be a good source of learning how to weld so you can justify the purchase of a welder (Tomstone for $100 or so?) and maybe if you get lucky you can get a shield with it.
David from jax
/ Brush hog advice
Watched some how to videos on welding. Explanation of types/methods, and based on what I've read, I would want the oxy/propylene setup for cutting/heating, not to be confused with propane. propylene is cheaper than acetylene, and although it technically has a higher temp at the inner core of the flame, when used with the proper type cutting tip, it will cut faster.
Oxy/propylene does not create a sheild around the weld area, so it is not a good choice for welding.
For welding I'd like a good stick welder. From what I read, they are easier for the novice to use, and handle heavy stiff well. They are not good for sheet metal.............So I'd probably like to have a mig setup for the lighter stuff.
Now all I need is a couple grand, and I'm off to the races!
Decided not to pull the stump jumper. Looked under it today, and noticed several welds/repairs on it, then measured the distance from each end of the large steel bar (blade carrier), to the underside of the deck, and it was equal, so only the pan part of the jumper is bent, and not enough to make me want to open that can of worms.
Steve W.
/ Brush hog advice
Yeah, he is a good guy. He has known me since I was a boy. He is a retired tool/die machinist, has 2 lathes, an old bidgeport, and an ancient looking "buzz box" stick welder..............handy neighbor to have.
Steve W.
/ Brush hog advice #115
I weld plenty of sheet metal with a 30/70a ac 120v stick welder using 1/16 or 5/64 rods. i use easystrike rods in 6013 for it.
welds nice! fender skins.. body panels, hoods.. etc..
soundguy
/ Brush hog advice #116
Personally I have never had much luck with stick welding thin stuff. I prefer to O/A if I dont have access to the tig. But thats just my opinion.
/ Brush hog advice #117
Tig for welding regular sheet metal really isn't that expensive as long as you scratch start it. Probably less than $300 would be my guess, though used those parts can be cheaper. Now add in water cooling, hi-freq start (or continous hi-freq for aluminum), reversible polarity, etc and you can start watching the $$$$$ go out the window. I actually have $235 in my Tig machine and it welds thin to 5/8" alum on single phase power, but I got lucky with that purchase. It is an oldie but goodie and was sitting at the University of Florida when they decided to upgrade. Foot pedal didn't have more than a scratch or two on the paint where you keep your foot.
Stevewtr, take some time and get the neighbor to show you how to run those machines (especially the welder). I met a guy in a night class machine shop that lived a few miles away, and would go spend an hour or two over at his house swapping stories or showing me the latest project on the mill or lathe. He retired as a toolmaker at the local base, and was just hitting the night school as a way to use some of the other machines available at low cost(versus buying another machine). The teacher learned from him, lol.
He was scheduled for double knee replacement and called me to see if I wanted to buy his Bridgeport and Southbend lathe. I gave him top dollar at the time (now way above the value due to drop in machine prices) He figured he would never stand in front of them again. He took the money and went on an Alaskan cruise with his wife. Now he comes over to my house to use the machines instead of me going over there.
David from jax
/ Brush hog advice
Stevewtr, take some time and get the neighbor to show you how to run those machines (especially the welder). David from jax
I took a machine shop night course at the local voc tech school, and got the basics on a lathe, bridgeport, horizontal milling machine, and surface grinder. Old equipment, but nice to learn on.
/ Brush hog advice
Part 5 is up for those of you following the progress on the old cutter:
[ame=http://www.youtube.com/watch?v=bVxtjoa6Oi4]Bush hog 305 part 5 - YouTube[/ame]
/ Brush hog advice #120
Steve...That's great your getting your apprentices to help you on your cutter.
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
Bulldozer Rake (A64127)
Bulldozer Rake...
2019 Dodge Durango SUV (A61574)
2019 Dodge Durango...
2022 EZ-GO ELITE...
