Brush Grubber
/ Brush Grubber #91
Hard to beat a chain and piece of pipe. Often use pipes on both ends of chain. Pipe bites the tree. If small trees are close, can pull several at a time. Easy to undo after pulling. Tried a grabber but didn’t work as well for me.
Spring cleaning around pastures and roads now before leafing out. Pulling encroachment trees, breaking off overhanging limbs and hauling off with Danuser Intimdator is pretty much hands free. A few trees and limbs will need to be polesaw cut.
Do you use this on your FEL, Backhoe or 3pt? What works best to use the chain/pipe? Great idea!
/ Brush Grubber #92
Right on the money about the pipe biting in.. If you have a bit of extra chain, you can just slip a plain piece of chain thru the pipe without the hook, weld a couple links on the side of the pipe and you're done. Make it as long as you think you need. No need to screw around cutting out a section of the pipe. There have been several mods on the original but this is the simplest, quickest and laziest way I can think of. If you have grab hooks on your loader bucket you don't even need a hook on the other end.. just a plain piece of chain welded on the side of a pipe.
/ Brush Grubber
Again, not a wise idea pulling weed trees using the grab hooks on a bucket because you can make your lift arms wonky with an uneven pull. Grab hooks on a bucket are fine for vertical lifting but not fine for pulling with. What the rear mounted drawbar is for.
/ Brush Grubber #94
You can post 'China' on here without fear of retribution....lol
<snipped>
Interesting side note.. When they refurbished the Big Boy steam locomotive, the feedwater pumps were shot and they had to buy them from China of all places. Probably rolling on Chinese made roller bearings too.
I read that someplace was reviving a historical railroad and the only complete, running steam engine they could buy came from China, brand new, nobody else makes them any more.
/ Brush Grubber #95
I pull little **** with the grab hooks on the bucket - stuff like scotch broom or blackberry knots, or t-posts; probably 200-300# pulling force at the most.
Medium stuff I go through the loop in the middle of the bucket; really tough stuff I bring the A-frame out and either pull that with a chain to the tractor draw bar or I use my truck winch, with the truck anchored to a tree (it really doesn't take much to skid an unanchored truck!).
WTB 4-wheel parking brake; I guess putting the truck in 4wd gets you 3+....
/ Brush Grubber #97
Maybe there isn't enough room to get the tractor in the area and you don't want to disturb surrounding trees?
Also, most of my problem saplings/brush have grown up because they're too close to nice trees to bush hog. Their roots are entwined with the good tree's roots. Pulling them out by their trunks is my best option.
/ Brush Grubber #98
Seems as though I have a ton of weed tree saplings that are too small for the chainsaw but large enough to yank out so I ordered the 'Brush grubber.. Anyone use one? Do they hold up? Gonna use it behind one of my M9's on the drawbar to yank them out. Got the 'heavy duty' model. Is it heavy duty enough for my 8K pound, 90 horse FWA Kubota or will I destroy it?
Original Brush Grubber did not work for me. It just slid up the tree while skinning the bark.
A 1/4 inch chain worked very well, basically by tying it to the tree using a clove hitch and pulling with tractor. The downside was climbing up and down to attach/detach chain from trees.
Now I use a tree/post puller (see Old Grind's photo). It is fast and easy and I can stack pulled trees for later removal; I just "curl" down until pulled tree is horizontal over the pile and drop. The limitation is the tractor weight, i.e. rear wheels lifting off ground even with ballast. This is mainly an issue with trees like sweet gums (even smaller ones) with a common root system.
/ Brush Grubber
Unless you have lockers on the front and rear axles, 4 wheel drive is a misnomer. It's still 2 wheel drive but one in the front and one in the rear.
In my case, my F350 has a Detroit Tru-Track locker in the back and an ARB air locker in the front and with both axles locked, you can really only drive in a straight line.
/ Brush Grubber #100
I used the FEL on my JD Loader on a JD 5310 (62 hp). Now 10 hears after I bought it and 25 years after it was made I need to rebuild my cylinders on the FEL. That is probably abuse but I would think anything under 3" would be fodders for 90hp? It wouldn't bother me to back over them with a box blade. Note that I am no expert. I used a chain on the FEL to pull T-Posts. The on and off was not fun. Occasionally, the chain slipped off but practice with the wrap technique helped.
2008 Jeep Wrangler Unlimited 4X4 SUV (A59231)
2008 Jeep Wrangler...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2014 Wanco NTCIP Towable Solar Message Board (A59228)
2014 Wanco NTCIP...
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
Rotary Brush Cutter Tractor Attachment (A59228)
Rotary Brush...
