Brush Cutter RPM
   / Brush Cutter RPM #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Does anyone know the max RPM of the Brush Cutter?
   / Brush Cutter RPM #2
JJ
Pt specs say PTO flow is 8 gpm, and with a 3.0 cubic inch per rev hydraulic motor, this equates to 618 rpm.
Hope this helps
Duane
   / Brush Cutter RPM
Thanks.
If I am right, that means that you are using 11.7 hp to turn the Brush Cutter on the smaller machines.
   / Brush Cutter RPM #4
That sounds about right, but you only use the amount of power you draw from the load of cutting and turning the mower. Just to turn the cutter would be alot less.
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
