Broken Tractor - Help!
/ Broken Tractor - Help! #1
Poncho
Tallahassee Florida
Massey Ferguson 2625 4wd
In woods today mowing shooting lanes and food plots, went over a wind row and came down the other side , hit a lighter tree stump and busted a housing under the tractor. I have a 431 tractor and the housing bolts to the right side of the main chassis and is connected at the end of a long tube that goes to the front of the tractor into what looks like a pump of some sort. The housing is square and bolts on with 3 bolts to the main chassis and looks to circulate hydarulic fluid (which completely leaskied out). I need the housing and the receiver section that bolts to the fron as it also got bent. Don't know what this is housing/unit is called and want to know what I'm into on $$.
Thanks,
/ Broken Tractor - Help! #2
Thanks,
Can you get a picture??
www.agcopartsbooks.com/
/ Broken Tractor - Help! #4
How ironic, I did the same well almost, a stump came up and bent the bracket that holds a few hydrolic lines on my passenger side underneath the floor board and ripped out the hydrolic line, was so pissed off that I jut parked the tractor and will look at it tomorow, but have a good hunch that it will be quite a few $$$$$..................grgrgrgrgrgrrrrrrr
With a pic we might be able to help you out more, I'm not familiar with the 431....
Well.... here's the damage. I also have a broken stud in the case that I will have to extract.
/ Broken Tractor - Help! #6
Have you ever tried a left hand drill bit for that?
The last time I had one, the drill bit quickly turned it right out.
that what i was thinking of using
/ Broken Tractor - Help! #10
Is this the part? oops, no, you said, "right side"... :D driver's side or passenger side :confused: Actually, I can't really tell from the diagram which side it's from...
Edit, got a photo of the tractor, where it came off?
That looks like it. It's on the right side of the tractor if your sitting on it. Thanks for the link... I just couldn't find anything because I didn't knwo what I was looking for.
/ Broken Tractor - Help! #12
Good, let us know how it works out... hope the parts don't break the bank!
thanks for the link help... looks like its a hydraulic filter housing and elbow. maybe it won't be too expensive.
Well... it's a hydraulic filter housing. New housing elbow equals about $18.50, new filter housing = $43 and a couple of new gaskets will be about $4.00 and new filter about $18..... all in all about $100 including hydraulic fluid. Thanks for the help guys.
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
2012 Freightliner FLD120 Ambulance (A64556)
2012 Freightliner...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
2015 Hitachi ZX75US Midi Excavator (A64553)
2015 Hitachi...
