Broken Tractor - Help!
/ Broken Tractor - Help! #1
Poncho
Tallahassee Florida
Massey Ferguson 2625 4wd
In woods today mowing shooting lanes and food plots, went over a wind row and came down the other side , hit a lighter tree stump and busted a housing under the tractor. I have a 431 tractor and the housing bolts to the right side of the main chassis and is connected at the end of a long tube that goes to the front of the tractor into what looks like a pump of some sort. The housing is square and bolts on with 3 bolts to the main chassis and looks to circulate hydarulic fluid (which completely leaskied out). I need the housing and the receiver section that bolts to the fron as it also got bent. Don't know what this is housing/unit is called and want to know what I'm into on $$.
Thanks,
/ Broken Tractor - Help! #2
Thanks,
Can you get a picture??
www.agcopartsbooks.com/
/ Broken Tractor - Help! #4
How ironic, I did the same well almost, a stump came up and bent the bracket that holds a few hydrolic lines on my passenger side underneath the floor board and ripped out the hydrolic line, was so pissed off that I jut parked the tractor and will look at it tomorow, but have a good hunch that it will be quite a few $$$$$..................grgrgrgrgrgrrrrrrr
With a pic we might be able to help you out more, I'm not familiar with the 431....
Well.... here's the damage. I also have a broken stud in the case that I will have to extract.
/ Broken Tractor - Help! #6
Have you ever tried a left hand drill bit for that?
The last time I had one, the drill bit quickly turned it right out.
that what i was thinking of using
/ Broken Tractor - Help! #10
Is this the part? oops, no, you said, "right side"... :D driver's side or passenger side :confused: Actually, I can't really tell from the diagram which side it's from...
Edit, got a photo of the tractor, where it came off?
That looks like it. It's on the right side of the tractor if your sitting on it. Thanks for the link... I just couldn't find anything because I didn't knwo what I was looking for.
/ Broken Tractor - Help! #12
Good, let us know how it works out... hope the parts don't break the bank!
thanks for the link help... looks like its a hydraulic filter housing and elbow. maybe it won't be too expensive.
Well... it's a hydraulic filter housing. New housing elbow equals about $18.50, new filter housing = $43 and a couple of new gaskets will be about $4.00 and new filter about $18..... all in all about $100 including hydraulic fluid. Thanks for the help guys.
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2016 JOHN DEER 1600 TURBO SERIES II (A66091)
2016 JOHN DEER...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
2010 Club Car Electric Cart. (A64557)
2010 Club Car...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2016 VOLVO L60H WHEEL LOADER (A65053)
2016 VOLVO L60H...
