Broken Tractor - Help!
/ Broken Tractor - Help! #1
Poncho
Tallahassee Florida
Massey Ferguson 2625 4wd
In woods today mowing shooting lanes and food plots, went over a wind row and came down the other side , hit a lighter tree stump and busted a housing under the tractor. I have a 431 tractor and the housing bolts to the right side of the main chassis and is connected at the end of a long tube that goes to the front of the tractor into what looks like a pump of some sort. The housing is square and bolts on with 3 bolts to the main chassis and looks to circulate hydarulic fluid (which completely leaskied out). I need the housing and the receiver section that bolts to the fron as it also got bent. Don't know what this is housing/unit is called and want to know what I'm into on $$.
Thanks,
/ Broken Tractor - Help! #2
Thanks,
Can you get a picture??
www.agcopartsbooks.com/
/ Broken Tractor - Help! #4
How ironic, I did the same well almost, a stump came up and bent the bracket that holds a few hydrolic lines on my passenger side underneath the floor board and ripped out the hydrolic line, was so pissed off that I jut parked the tractor and will look at it tomorow, but have a good hunch that it will be quite a few $$$$$..................grgrgrgrgrgrrrrrrr
With a pic we might be able to help you out more, I'm not familiar with the 431....
Well.... here's the damage. I also have a broken stud in the case that I will have to extract.
/ Broken Tractor - Help! #6
Have you ever tried a left hand drill bit for that?
The last time I had one, the drill bit quickly turned it right out.
that what i was thinking of using
/ Broken Tractor - Help! #10
Is this the part? oops, no, you said, "right side"... :D driver's side or passenger side :confused: Actually, I can't really tell from the diagram which side it's from...
Edit, got a photo of the tractor, where it came off?
That looks like it. It's on the right side of the tractor if your sitting on it. Thanks for the link... I just couldn't find anything because I didn't knwo what I was looking for.
/ Broken Tractor - Help! #12
Good, let us know how it works out... hope the parts don't break the bank!
thanks for the link help... looks like its a hydraulic filter housing and elbow. maybe it won't be too expensive.
Well... it's a hydraulic filter housing. New housing elbow equals about $18.50, new filter housing = $43 and a couple of new gaskets will be about $4.00 and new filter about $18..... all in all about $100 including hydraulic fluid. Thanks for the help guys.
2016 Ford Explorer SUV (A64557)
2016 Ford Explorer...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2022 EZ-GO ELITE...
