Broken snow blade
/ Broken snow blade #1
buck boost
Paris, WI
Ford 4500 LB, M7040HD, B2920
Users of a B2765 plow beware. This fall I purchased the 60" snow blade and quick hitch setup for my B2920. Used all winter here in SE WI with very good success. Until yesterday. Somehow I managed to clip the right edge of the blade on a chunk of frozen gravel and it shock loaded the angle ram on the and blew the end out.
The ram end is held together not by a threaded end, but by a snap ring. It deformed the end of the tube when the end blew out. Seems to be a cheesy/cheap way to build cylinder. I had the trip mechanism set to the loose side, so the way I clipped the ice/gravel ball must have been perfect lol.
The cylinder from kubota, which I found online, is priced at $601. Very pricey I think for such a cheaply made cylinder.
I will calling my local dealer tomorrow to hopefully have this warrantied. Snow is still flying!
/ Broken snow blade #2
Was a cushion valve installed between the angle cylinders and control valve?
Proper plow setups have these to by-pass excessive pressure from hitting obstructions in your path while plowing, preventing a.............Boooooooom
/ Broken snow blade
No cushion valve installed. The hydraulic lines come right out of the joystick valve directly to the single angle cylinder and lift cylinder. It should have either a stronger single cylinder or dual angle cylinders I think. It did not take much of a bump to blow the end off.
/ Broken snow blade #4
I'm sure you could get a cheaper cylinder, elsewhere.
$600 for such a small cylinder is ridiculous.
/ Broken snow blade #5
Hopefully your spring was set to trip. When I got my plow last year the dealer had the spring settings for "bull doze" not snow plowing......just saying
/ Broken snow blade #6
If the dealer won't warranty it and I don't think he will, get to a hydraulic shop with the busted cylinder. They should be able to get you a cylinder that is way better and cheaper, too.
/ Broken snow blade
The blade was set to trip, but now I set it as light as it goes. The dealer did not do the install, I did.
I talked to the dealer yesterday, dropped off the cylinder. The service manager said that they will warranty it. It should be here by Friday.
/ Broken snow blade #8
are you going to put the cushion valve in
/ Broken snow blade #9
my plow doesnt have a cushion valve... at least i dont think so. what are they and where are they??
EDIT: i went to surpluscenter's site and found them. about $70. i think ill look into this
/ Broken snow blade #10
Cushion valves work if you have a pair cylinders......under extreme pressure (hitting objects with the blade) they by-pass the high pressure oil to the opposing side
If you have one double acting cyl like the OP (with one hyd rod) the displacement on each side of the cyl is different and doesn't work the same.....in order for that to be effective You'd need work port reliefs in the main control valve
/ Broken snow blade #11
prince has double relief valve you can add on . about 100 bucks .
/ Broken snow blade
Sounds like I have a little homework to do.
Thanks guys.
/ Broken snow blade #13
Cheer up, it'll be melting before ya know it..:drink:
/ Broken snow blade
:D. I keep telling myself it will all be over soon! I will look into that prince relief/cushion valve. I hope I can get my old cylinder back also. I am devising a way to make a repair on the old one.
On the bright side, the blade still has manual angle lock out so I can still use the blade. Just got a couple of inches of fresh snow. And It always drifts right where I don't want it to!
And just a side note, overall I'm a very satisfied B2920 owner. It pulls the mmm, 4' cutter, bx42 chipper, and the snow blade very well. The loader works great too.
/ Broken snow blade #15
oh...i see. i have only one valve.
/ Broken snow blade #16
That would be sweet if they will give you the old one for a spare......worth patching it up:thumbsup:
It's good you have the manual lock pins.....do you suppose they want you to use the pin to prevent cyl blow-out?
/ Broken snow blade #17
If you have the ktac insurance and your still making payments you could go that route, file a claim, deductable is $250 but the dealership comes, gets it and fixes it.
/ Broken snow blade #18
They are usually mounted on the frame (or subframe) and have the four lines running through it. If one side see's an overpressure situation like hitting a curb then the pressure is "relieved" or "crossed over" to the other side letting the plow turn.
Here is a picture on my JD #380 plow:
/ Broken snow blade #19
Good question....what does that warning label in the last pic of the first post say? OP, sure you are not supposed to pin the blade?
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
YALE FORKLIFT (A63291)
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
HYUNDAI HL770-9A WHEEL LOADER (A65053)
HYUNDAI HL770-9A...
