Broken Lower Bushing
/ Broken Lower Bushing #1
PTRich
Willington, CT
Power Trac PT425
About 2 weeks ago I broke the lower bushing on my pt425 where it articulates. I was trying to pull it out of some very deep mud that I should not have gone in, it was over 2 feet deep. I cut the old bushing off with a sawzall with a new metal blade. Worked realy good. I then ground it down flush with a right angle grinder. I welded it with a stick welder and it is now as good as new.
/ Broken Lower Bushing #2
Did you take any pictures, before and after?
/ Broken Lower Bushing #3
Glad you were able to repair it. Did you have to get a new bushing? If so, where did you get it?
I did not take pictures. I did'nt have time.
The bushing had a piece broken off it. I assumed you have to buy it from Power Trac but did not look elsewhere. The repair was easier than I thought it would. I have never done anything like that before.
/ Broken Lower Bushing #6
PTRich,
How much was the bushing assy from PT. I have'nt seen anything like it in any supply catalogs/tractor supply places.
Duane
2018 John Deere UTV Blade (A63116)
2018 John Deere...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Topsoil Trommel (A57453)
Topsoil Trommel...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
(4) SIDE BOXES (A63569)
(4) SIDE BOXES...
DSP 900 Balancer with Split Weight (A63118)
DSP 900 Balancer...
