Broken Front Shocks
/ Broken Front Shocks #1
FordT
Yesterday while spraying a pasture sideslope I broke a front shock. Apparently something flew up and through my fender. I'm a bit disapointed as my other equipment traverses this same pasture without difficulty or mechanical failure. In fact I continued my spraying operation with my stock Ford Explorer without difficulty. Has anyone else had this problem?
/ Broken Front Shocks #2
Which TC version do you have?
jmf
I belive it's a B. How do you differentiate between A,B, and C?
/ Broken Front Shocks #4
The C has independent suspension.
jmf
Mine has solid axles so it must be a B.
/ Broken Front Shocks #6
The 'A' model has a box boom (can't see through the middle) and white arms from the boom to the tilt mechanism.
The 'B' model has a box boom (can't see through the middle) and black arms from the boom to the tilt mechanism.
The 'C' model has a two piece boom that is open in the middle (can see through).
The 'D' model is the only model (currently) with independent rear suspension.
dsb
OK mine is a B model.
Thank you both for your clarification. Any one else had shock/spring failure.
Ford
Thanks, I sent a message to him asking him to join the discussion.
FordT
/ Broken Front Shocks #10
As I recall, Dylan had rear leaf spring failure, not shock failure.
Do not recall anyone else having shock breakage.
/ Broken Front Shocks #11
hi guys
I broke both rear springs this winter.
I had a problem with one front spring when i first purchased the machine. it sat 3-6" lower on one side than the other. the dealer replaced that spring and it was good for a week and then it happened again. he replaced the spring a second time and it has been good for two years now.
Makes me wonder if there was a run of defective shocks early on. I have only 360 hours of residential (not commercial) use on my toolcat. Anyone with more info./input?
FordT
2105 (A65055)
2105 (A65055)
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2003 Dodge Ram 1500 Crew Cab Pickup Truck (A64556)
2003 Dodge Ram...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
2011 Caterpillar 420E 4x4 Extendahoe Loader Backhoe (A64194)
2011 Caterpillar...
2001 VIBROMAX W1106PD ROLLER (A66091)
2001 VIBROMAX...
