Broken Front Shocks
/ Broken Front Shocks #1
FordT
Yesterday while spraying a pasture sideslope I broke a front shock. Apparently something flew up and through my fender. I'm a bit disapointed as my other equipment traverses this same pasture without difficulty or mechanical failure. In fact I continued my spraying operation with my stock Ford Explorer without difficulty. Has anyone else had this problem?
/ Broken Front Shocks #2
Which TC version do you have?
jmf
I belive it's a B. How do you differentiate between A,B, and C?
/ Broken Front Shocks #4
The C has independent suspension.
jmf
Mine has solid axles so it must be a B.
/ Broken Front Shocks #6
The 'A' model has a box boom (can't see through the middle) and white arms from the boom to the tilt mechanism.
The 'B' model has a box boom (can't see through the middle) and black arms from the boom to the tilt mechanism.
The 'C' model has a two piece boom that is open in the middle (can see through).
The 'D' model is the only model (currently) with independent rear suspension.
dsb
OK mine is a B model.
Thank you both for your clarification. Any one else had shock/spring failure.
Ford
Thanks, I sent a message to him asking him to join the discussion.
FordT
/ Broken Front Shocks #10
As I recall, Dylan had rear leaf spring failure, not shock failure.
Do not recall anyone else having shock breakage.
/ Broken Front Shocks #11
hi guys
I broke both rear springs this winter.
I had a problem with one front spring when i first purchased the machine. it sat 3-6" lower on one side than the other. the dealer replaced that spring and it was good for a week and then it happened again. he replaced the spring a second time and it has been good for two years now.
Makes me wonder if there was a run of defective shocks early on. I have only 360 hours of residential (not commercial) use on my toolcat. Anyone with more info./input?
FordT
ALUMINUM TRUCK TOOL BOX (A64278)
ALUMINUM TRUCK...
2148 (A65055)
2148 (A65055)
2015 Jeep Renegade Latitude SUV (A64557)
2015 Jeep Renegade...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
72in. Fork Extension (A64553)
72in. Fork...
GEN POWER 40KW GENERATOR (A64278)
GEN POWER 40KW...
