Broken Crank
/ Broken Crank #21
Glad your mechanic caught it this time before the install. Makes you wonder how many others out there. Hopefully you'll have your tractor repaired and back to you soon.
/ Broken Crank #22
I looked at our cranks last night & they do all have the same marking in the same place. It appears to me that it is either a scuff or maybe a series of small dents in a straight line along the outside of the rod bearing journal. To me it looks more like something caused by a clamp or a mount of some sort that they may have used to hold the crank during manufacturing or during painting, etc. But... it is very small and it could possibly be a casting defect that almost got machine out when the turned it down. This is the first problem we have seen with them though but it is also a fairly new item.
There is only 1 company importing these cranks so they are the same exact cranks that everyone else is selling and I have not heard about any problems from them either. I have contacted the supplier and they are going to check out their stock and see what we can figure out.
I'll keep you posted.
Aaron
Parts@HoyeTractor.com
(940)592-0181
/ Broken Crank #23
In my experiece a scratch across the face of metal will set up a fracture point. If the scratch is very shallow it probably could be polished out, which will remove the point of a fracure occuring. I learned this about forklift forks. If they are dented across the narrow face they will eventually break there. The fix is to take a die grinder and polish the dent out with the length of the fork.
/ Broken Crank #24
Aaron , I know you are just guessing as to why the scuff or small dents are there ,but I can't understand why someone would clamp or attatch something (that would scuff or mar) part of a machined rod bearing or crank bearing journal Hopefuly you will get an answer & let us know. Thanks
/ Broken Crank
I retrieved the two cranks last night. Here are the photos of the broken crank, which I bought in August. I hope you are able to see the texture of the inside of the break well enough in the photos.
/ Broken Crank #26
That looks like a crankshaft out of a 2 cyl, I thought you said it was a YM2010. There have been some problems with the aftermarket 2cyl crankshafts.
Danny
/ Broken Crank #28
The break fracture seems very course to me. My thoughts are improper tempering and case hardening???:confused: :confused: :confused:
/ Broken Crank #29
The photos are not very clear--It wouls sure help diagnosis if we had some really clear pics. I do not mean to be critical, but it is hard to see the grain structure of the metal in a blurry photo. Your kitchen and dining room are in focus though. ;)
Mike in Warsaw
/ Broken Crank
Yes, it is a 2 Cylinder YM2210. I mistyped on the original post.
I will see if I can get some clearer pictures tonight.
/ Broken Crank #31
I knew there were a few problems with that crankshaft, but yours is the first one that I know of that broke after it got to the end user. I don't know of any of the one's I've sold that have had any problems.
Danny
2013 FORD E-SERIES VAN (INOPERABLE) (A67714)
2013 FORD E-SERIES...
PALLET OF MISC SIZE STYLED JACKS (A67714)
PALLET OF MISC...
2025 48in. Farm Jack (A66734)
2025 48in. Farm...
2003 Ford F-350 4x4 Crew Cab Flatbed Truck (A66736)
2003 Ford F-350...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
