Broken Crank
/ Broken Crank #21
Glad your mechanic caught it this time before the install. Makes you wonder how many others out there. Hopefully you'll have your tractor repaired and back to you soon.
/ Broken Crank #22
I looked at our cranks last night & they do all have the same marking in the same place. It appears to me that it is either a scuff or maybe a series of small dents in a straight line along the outside of the rod bearing journal. To me it looks more like something caused by a clamp or a mount of some sort that they may have used to hold the crank during manufacturing or during painting, etc. But... it is very small and it could possibly be a casting defect that almost got machine out when the turned it down. This is the first problem we have seen with them though but it is also a fairly new item.
There is only 1 company importing these cranks so they are the same exact cranks that everyone else is selling and I have not heard about any problems from them either. I have contacted the supplier and they are going to check out their stock and see what we can figure out.
I'll keep you posted.
Aaron
Parts@HoyeTractor.com
(940)592-0181
/ Broken Crank #23
In my experiece a scratch across the face of metal will set up a fracture point. If the scratch is very shallow it probably could be polished out, which will remove the point of a fracure occuring. I learned this about forklift forks. If they are dented across the narrow face they will eventually break there. The fix is to take a die grinder and polish the dent out with the length of the fork.
/ Broken Crank #24
Aaron , I know you are just guessing as to why the scuff or small dents are there ,but I can't understand why someone would clamp or attatch something (that would scuff or mar) part of a machined rod bearing or crank bearing journal Hopefuly you will get an answer & let us know. Thanks
/ Broken Crank
I retrieved the two cranks last night. Here are the photos of the broken crank, which I bought in August. I hope you are able to see the texture of the inside of the break well enough in the photos.
/ Broken Crank #26
That looks like a crankshaft out of a 2 cyl, I thought you said it was a YM2010. There have been some problems with the aftermarket 2cyl crankshafts.
Danny
/ Broken Crank #28
The break fracture seems very course to me. My thoughts are improper tempering and case hardening???:confused: :confused: :confused:
/ Broken Crank #29
The photos are not very clear--It wouls sure help diagnosis if we had some really clear pics. I do not mean to be critical, but it is hard to see the grain structure of the metal in a blurry photo. Your kitchen and dining room are in focus though. ;)
Mike in Warsaw
/ Broken Crank
Yes, it is a 2 Cylinder YM2210. I mistyped on the original post.
I will see if I can get some clearer pictures tonight.
/ Broken Crank #31
I knew there were a few problems with that crankshaft, but yours is the first one that I know of that broke after it got to the end user. I don't know of any of the one's I've sold that have had any problems.
Danny
2018 Nissan Frontier Ext. Cab Pickup Truck (A66736)
2018 Nissan...
2015 Freightliner (A64119)
2015 Freightliner...
Pop Up Camper (A66738)
2012 Mercury 25HP Outboard Boat Motor. (A66738)
2012 Mercury 25HP...
2007 CAT 140H MOTOR GRADER (A67714)
2007 CAT 140H...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
