broken antenna
/ broken antenna #1
jajiu
Rowley, MA
Kubota L3560 HSTC
I broke the stud off the antenna base. I got it out of the antenna mast, but now I need the round piece with the stud. The dealer said he could only sell me the complete antenna for $80. The part I need probably is only about $5. if that. Anyone have any ideas? By the way, this is on my 2014 L3560HSTC.
/ broken antenna #2
Maybe try E-bay? Of course you could also look in Ali-baba since it is likely asian in origin.
/ broken antenna #3
Let us know if you find one. I wasn't able to find one on line so I went the expensive full replacement way and threw away most of the parts. Now I run with the antenna horizontal or down and suffer the poor reception.
/ broken antenna
Thanks for the encouraging information. I have looked everywhere, gone to auto parts stores, Walmart, Kmart, etc. I have gone thru almost every site on the internet and nothing. Not even a cheap replacement can be found. I think Kubota does this on purpose so you need to buy from them. I know United Shoe use to make screws and things with a special thread so you had to buy from them not the hardware store. I'll keep looking for a while but I know I will end up biting the bullet and buying the "Full Monte".
/ broken antenna #5
can you post a pic please
/ broken antenna
I had to wait for the rain to stop before going to the barn or I would have gotten soaked. Here are a few pics. I ordered an antenna from ebay. It was cheap enough and looked like a close match, I'll post when I get it and try to install it. P7180011.JPGP7180005.JPGP7180001.JPGP7180003.JPG
/ broken antenna #7
why couldn't you drill and tap the base? that is also the same type of antenna I have on my jeep that I picked up at a the auto parts store a few years ago .
/ broken antenna
When I looked at the antenna, it looked like the stud broke off the antenna and I drilled a hole in the base and tried to use an easy out and it broke off in the hole. Now the hardened steel is embedded in the base. I tried to get it out but the base is white metal and was easily destroyed.
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
Towable Generator (A60352)
Towable Generator...
2011 PETERBILT 367 (A65643)
2011 PETERBILT 367...
NEW ATS-SP100 100 Ton Capacity Shop Press  (A62679)
NEW ATS-SP100 100...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
John Deere HX15 (A64126)
John Deere HX15...
