Bridge Load Limit
   / Bridge Load Limit #11
Just tell him to close his eyes & go real fast!
   / Bridge Load Limit #12
Do you know of anyone who knows anyone who is a good engineer?
Pretty simple build and a good engineer could give you a ballpark fairly easy. (not PE stamped) but you could still get a close idea.
If you PM me a list of structure components with dimensions and spans (a good pencil drawing would be perfect) I could have some of my mechanical engineer colleagues give you a back of napkin calculation.
   / Bridge Load Limit
Thank You redheelerdog,
I respect the drivers decision, and would like to have something to give to him in regards to limit etc.
Trying to explain rolling load (driving over it) vs static load (parking on it)
Sent you a PM.
Again Thanks,
JW5875
   / Bridge Load Limit #14
   / Bridge Load Limit #15
Here are a couple of bridge design pages from various state highway commissions and railroads
Timber Bridges
Concrete Bridges
I am a former Civil engineer (non practicing), and never dealt specifically with small bridge construction.
I am on the side of your "current driver".
From your photos, I absolutely would not take a fully loaded tri-axle dump over that bridge.
   / Bridge Load Limit #16
Its to much risk if it collapses and any fuel gets in the water....... BIG trouble.......
   / Bridge Load Limit #17
With the comments being posted you might just want to toss down a tin horn (culvert) next to it and dump the first load of gravel on it for the truck crossing. Then move the gravel to where you need it when the truck has finished all of the loads. Assuming there is several loads. To bad the company you have already dealt with that crossed it in worse condition is not available.
   / Bridge Load Limit #18
Change it to a draw bridge and put some big alligators down in there like a moat of doom, people won't bother you then. :thumbsup:
   / Bridge Load Limit #19
The OP lives in NW PA.
Alligators do not do well that far North!
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
