Bridge Load Limit
/ Bridge Load Limit #1
Jw5875
Gold Member
NW Pa.
Kubota L3400
Lost my bridge several times over the past 12 yrs. and decided to do
a new design. Raised it and removed some rocks from under it for a
better flow of high water.
Bridge was originally on 4 - 17' x 10" x 5" x 3/8 beams with same dimensions of an
8" beam in the middle with a 17' span for the bridge.
Had several tri axles of gravel cross it at different times and just a little flex, due to
ends sitting on rocks.
Now have the beams on 2' x 2' x 6' concrete blocks at a 12' 9" span under the same beams.
Current driver feels bridge is not capable for a tri axle of 2A stone?
Can some one point me to the load capacity?
Pic 6 is flood damage.
Thanks,
JW5875
/ Bridge Load Limit #4
Your county may evaluate bridges, to see if they will send a fire truck across it.
Bruce
/ Bridge Load Limit #5
Should have buried another course of block below the water level. As constructed it won't take long for the foundation to wash out.
/ Bridge Load Limit #6
We have several fields that we have to cross a small brook to get to,
were we have installed culverts in a few places we also maintain an actual stream crossing.
Heavy or loads too wide to fit will use the stream crossing our ground is quite stony so the crossings are very firm.
Looking at your bridge construction it certainly seems to be more then strong enough for that span.
I haven't looked recently but they used to be some design calculators on line for defection under load for steel or timber.
/ Bridge Load Limit #7
As close as I could come up with was: 7800 pounds per square foot.
Assuming half the tuck was on the bridge at one time (because a tri axle is longer than 17 feet), then 72,000 pounds divided in half=36,000 pounds.
Assuming 2 square foot for each tire for easy math, with 2 big front tires on the bridge (4 square feet)=31,200 pounds
Assuming 1/2 square foot for each rear tire for easy math, with 12 tires=46,000 pounds.
(Now these are VERY rough numbers. I am not sure exactly how the real weight transfers on a truck, but it seems it will hold a truck...barely because the front end would be less than half the weight of the loaded truck, but has less square surface of tires bearing down on the bridge. In the back end, the load is spread out over more square feet, but the weight is probably greater too.
This is done with 1/2 inch deflection being pass or fail.
/ Bridge Load Limit
We dug down with the excavator as far as we could, creek base is almost solid stone / rock.
/ Bridge Load Limit #9
Seems you already have a history of loads on a less well built bridge and it worked. Of course its the current drive you have to deal with. He is naturally concerned about damaging his equipment. And your bridge.
If you have a rock base under it that the blocks are setting on as it seems front the post how about some jack post set up under the bridge mid way for extra support and for the drivers price of mind. Usually available at box stores and lumber yards.
Just guessing at your height but the linked post are rated at 20,000 lbs at max height, each. around $60 dollars each with tax.
https://www.lowes.com/pd/Akron-56-in-Adjustable-Jack-Post/3201385
/ Bridge Load Limit #10
Almost 20k on the front axle and about 56k on the 3 rear axles gross of 76k that's what we run on are trucks, A 24 ton load + or -
/ Bridge Load Limit #11
Just tell him to close his eyes & go real fast!
/ Bridge Load Limit #12
Do you know of anyone who knows anyone who is a good engineer?
Pretty simple build and a good engineer could give you a ballpark fairly easy. (not PE stamped) but you could still get a close idea.
If you PM me a list of structure components with dimensions and spans (a good pencil drawing would be perfect) I could have some of my mechanical engineer colleagues give you a back of napkin calculation.
/ Bridge Load Limit
Thank You redheelerdog,
I respect the drivers decision, and would like to have something to give to him in regards to limit etc.
Trying to explain rolling load (driving over it) vs static load (parking on it)
Sent you a PM.
Again Thanks,
JW5875
/ Bridge Load Limit #15
Here are a couple of bridge design pages from various state highway commissions and railroads
Timber Bridges
Concrete Bridges
I am a former Civil engineer (non practicing), and never dealt specifically with small bridge construction.
I am on the side of your "current driver".
From your photos, I absolutely would not take a fully loaded tri-axle dump over that bridge.
/ Bridge Load Limit #16
Its to much risk if it collapses and any fuel gets in the water....... BIG trouble.......
/ Bridge Load Limit #17
With the comments being posted you might just want to toss down a tin horn (culvert) next to it and dump the first load of gravel on it for the truck crossing. Then move the gravel to where you need it when the truck has finished all of the loads. Assuming there is several loads. To bad the company you have already dealt with that crossed it in worse condition is not available.
/ Bridge Load Limit #18
Change it to a draw bridge and put some big alligators down in there like a moat of doom, people won't bother you then. :thumbsup:
/ Bridge Load Limit #19
The OP lives in NW PA.
Alligators do not do well that far North!
