Bridge Load Limit
/ Bridge Load Limit #21
Could you have him carry a lighter/partial load or a smaller truck?
/ Bridge Load Limit #22
The real problem is with the I beams used. There was quite a bit of talk about the other components of the bridge, but it does not really matter. They are sitting on (4) 10 inch I beams only 3/8 thick. The thickness is not so much of a concern, as much as their depth. 10 inches is not that strong.
But the real, real, real issue is: you have a trucker that will not cross it, and I doubt that would change if you had built it out of 20 inch deep I beams. So, you really need a new truck driver.
Or, have him dump on this side of the bridge, and use your tractor and bucket to ferry it over the bridge, as long as the distance is not that far.
/ Bridge Load Limit #23
Would only have to dump some of it. Be easier and less costly to just haul smaller loads I suspect. Or find another supplier.
/ Bridge Load Limit #25
For your situation either make a bypass on the creek bed or get some stamped plans.
The bridge looks good at first glance and may be quite strong but looking more closely every aspect of it starting with the footings would negate getting proper approval from any authority. I would doubt a professional would even try to determine an acceptable load for the bridge. Relying Only on beam tables for design strength is a far cry from how the bridge design works.
/ Bridge Load Limit #26
The bridge looks good at first glance and may be quite strong but looking more closely every aspect of it starting with the footings would negate getting proper approval from any authority. I would doubt a professional would even try to determine an acceptable load for the bridge. Relying Only on beam tables for design strength is a far cry from how bridge design works.
/ Bridge Load Limit #27
^^^^^^EXACTLY why I stated ..ABSOLUTELY WOULD NOT...in my post #15.
I asked one of my old Civil engineering college roommates about this too. He is a retired state DOT Registered Professional Engineer (still does bridge const. consulting).
He said: Not only NO, but HE11 no!
/ Bridge Load Limit #28
But to be fair, I would expect that. They design bridges for a safety factor of two or more.
He would cringe if he saw some of the bridges we have hauled 100,000 pound loads of logs over, but as I said in my first post, it is not often you have a bridge so long that the whole truck is on the bridge at once.
Here is a fun fact though: Maine had the first weight limits for trucks.
/ Bridge Load Limit #29
Google a software tool called "Beam Boy". This is a very simple to use engineering tool that will calculate stress and deflection for you. Download BeamBoy 2.
Garbage in = garbage out so you need to be careful of your assumptions. This SW has selectable beams (just pick the one you are using) or you can spec out your own (more complicated).
/ Bridge Load Limit #30
As has been mentioned there are quite a few more factors involved than a set tables.
/ Bridge Load Limit #31
My Civil engineering RPE former roommate lives in Winthrop, Me. and is retired from the Maine DOT.
After nearly 60 years, we still talk by phone.
A really great "Mainiac" guy talking with his "Masshole" classmate.
/ Bridge Load Limit #32
He probably knows my ex-father-in-law, he worked for the MeDOT all his life as a surveyor. He is long since retired, and I lost track of him when I got divorced from his daughter.
He was telling me, back in the 1980's, he had to scale Mt Katadin because the State wanted to survey a road to the top. He said it was stupid because anyone knows, when Governor Baxter gave the state the land for that park, it specifically states, "No Motor Vehicles" so they would never build a road to the top. Still, somewhere, they have a map of a road on how to get to the top.
But he was interesting. When I fist met him...the very first time, he did his research on me and said, "Oh yes, the BrokenTrack family, you sold 100,000 yards of gravel to the MeDOT in 1969, at 10 cents a cubic yard, with you grandfather loading the gravel with his tractor..." It was all true. I have since tried to find that report so I could see what the Maine Geological Society had for information on the pit, but it seems no one but him could find the report.
/ Bridge Load Limit #33
I would certainly assume that he would know your ex-father-in-law
I believe that Brian may have actually started with ME DOT as a surveyor in 1961.
/ Bridge Load Limit
Well Gents,
A fellow TBN'r helped me with the information I needed.
Many Many "Thanks" to him and his team.
MY decision is to reduce loads to a tandem axle truck to
keep all parties agreeable to the suggested weight capacity of
the bridge.
JW5875
/ Bridge Load Limit #36
/ Bridge Load Limit #37
What's funny is if you've ever seen some of the 'temporary logging bridges' in this country that fully loaded trucks cross yours looks like the Golden gate. But, at the end f the day, it's the driver who pays the price. Saying "but he said it was good" doesn't cut it with the boss or the insurance company. Glad you've found a compromise everyone can live with.
/ Bridge Load Limit #38
A friend of mine in Canada, was driving a log truck over just such a bridge, and the bridge failed.
Took nearly 5 years, and lots of attorney (barrister there) dollars to finalize the case.
/ Bridge Load Limit #40
When I was a teenager in Ohio, the historical covered bridges were open for vehicle traffic, but normally had a weight limit of 5 tons for them. One day there was a picture in the paper of a fully loaded dump truck that had fallen thru the floor of the covered bridge. I don't remember what the outcome of that was but I can guess.
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2006 Ford F53 Landau 3645DS 36ft. Class A Motorhome (A61574)
2006 Ford F53...
2023 KMC 3pt 6 Row Rolling Cultivator (A64119)
2023 KMC 3pt 6 Row...
MacDon 963 Draper Header (A63688)
MacDon 963 Draper...
2013 Nissan Pathfinder 4x4 SUV (A61574)
2013 Nissan...
