Snow Equipment Owning/Operating Breaking shearbolts
/ Breaking shearbolts #21
Oh goody!
I know I am a little tight by times, but never crooked. I agree that high torque on the shear bolts will work them, I did not know that rotational forces, out of whack would too. Stands to reason. Is a snowblower impeller ever in balance? Good Post Phil!
Not normal...
2011 , first year I had my new front snow blower, 5 or 6 shear bolts in a nick of time! The dealer could send a competent mechanic. He isolated one by one every potential source of the problem. He found out a crooked shaft. He swamped the problematic piece on another snow blower, since then, not a single shear bolt was deheaded! There must be something a little off in your setup. Something over tight? Offset?
I just got back from dropping everything off at the dealer. Hopefully they have someone to figure it out. Thanks for commenting. I'll mention it to them.
/ Breaking shearbolts #23
Agreed. I haven't broken any shear bolts on my JD snowblower but have replaced 2 worm drives at $275 each. The $3 item should be protecting the $275 item not the other way around!
/ Breaking shearbolts #24
The used 3-point blower I picked up last summer has been pressed into use a few times here. No big snows so far, but a couple really heavy ones. I went through two shear bolts so far. One was when I used the blower to locate a landscape timber. The second one was when I was in a hurry doing a parking lot with about 4-5" of snow that was more like slush. I travelled faster than the blower could clear itself and ended up filling the auger solid. I use 1/4-20's with nylock nuts. There's a zippered tool bag under the seat with plenty of nuts & bolts, wrenches, pins, etc. Fortunately the bolts are very easy to replace.
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
Mack T/A Day Cab Truck Tractor (A64556)
Mack T/A Day Cab...
2018 TAKEUCHI TL8 SKID STEER (A65053)
2018 TAKEUCHI TL8...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
TAKEUCHI TB260 EXCAVATOR (A65053)
TAKEUCHI TB260...
