Breaking into the bank
   / Breaking into the bank #31
I am very interested in this project as I hope to build in a similar situation, however mine would be four foot walls with frame construction on top of that and a gambrel second story. My question is how deep is the footer in the front of the building?
BTW I think an entry to the second level from the rear ground level would very handy to have.
   / Breaking into the bank #32
JimmyJ, I see you have a quote from Carl Sandberg on your posts. My oldest daughter lives only about 7 to 8 miles from where his house is, he lived in, in Flat Rock, N.C. zman:cool:
Great input, thanks gents! The cavities have been re-barred and poured. Pics are on the way.
I think I will go with the outside entrance, and it seems to be strongly supported here. That will also allow me to have a door with a window, letting in more light from the south.
Maclawn - the block is tarred with a roller to waterproof it. As an added measure, I've used buttonboard on the back wall. Will get some pics of that as well.
Mike - the footers in the front of the garage are 40" deep. You can see the depth on the sides and back are minimal, since they will be well below grade.
   / Breaking into the bank #34
Looking good, scout! On the third photo above, what is the painted-looking line on the right side of the blocks sloping down about ground level? Is that some kind of water proofing? Sorry to keep harping on the water seeping in issue, but, man, have I seen some water problems with below grade concrete/blocks, etc. If you build below grade, you MUST make sure no water will seep in. I think you are covering it with the drain you mentioned, and definitely sloping the grade away from the wall will help, but water does have a way of its own... Keep the post and photos comin'.
What is buttonboard? Some kind of water proofing?
Blocks filled in. 2nd picture shows the buttonboard. The waterproofing company used it on the cracked wall on the house, so I decided to add it to the back wall of the shop. Just another soldier against water!
Maclawn - yes, the black angling line is waterproofing. With solid drain pipe, (holes on top) and backfilling gravel all the way up the block, it should give the water a way out and away from the foundation.
Last pics are a little brickwork to match the house.
   / Breaking into the bank #36
Thanks for the comments! I'm really at odds on how to access the loft storage.....I like the fact of being able to access from inside, but it will take up quite a bit of space....the outside access is appealing to walk straight in.....I'm thinking perhaps an outside entrance, with a vertical wall ladder on the back wall, to minimize space lost?
If I were you, I would consider a small balcony on the very front and center just for the enjoyment, with a door of course that opened into the upstairs. It doesn't help you get access to the upstairs from the ground though (unless you figured out someway to build some stairs up to it.
Nice project though, I'm sure you'll get it all figured out in the end. Good luck, and thanks for sharing it!
Back-filling the walls with gravel.....
   / Breaking into the bank #38
With all the attention you've paid to drainage and sealing, your walls will probably be OK. Particularly for a long run of wall, one or more deadman anchors can help prevent buckling. Alternatively one or more buttresses on the inside of the wall can brace it (but break up the smooth wall run). Here is a discussion of some of the issues and solutions:
Retaining wall - Wikipedia, the free encyclopedia
One of your pics shows a huge, paved parking lot just below the house. You must throw really big parties; its nice of you to provide paved parking for your guests...or maybe that's contractor parking?!!
BOB
BOB
Bob - tks for the link - good info!
The parking lot is for the golf course right across from me....gets to be a bit aggravating listening to all the happy chatter and knocking balls around when I'm on the hill slaving away!
   / Breaking into the bank #40
Something to consider with the buttonboard (www.platon.com, btw, and for sale at Menards around here anyway) - mine tore at the top edge from settling against it. No mention of this possibility from the manufacturer. :/
It's looks like it's maybe too late now, but I'd think about backfilling in lifts, running a compactor after each course.
2013 FORD F150 LARIAT CREW CAB TRUCK (A51243)
2013 FORD F150...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
2007 International 4300 DT466 Refer Truck (A47384)
2007 International...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
John Deere 335 Round Baler (4ftx4ft) (A52128)
John Deere 335...
