Branson BL20 Quick Connect Bucket to Skidsteer Adapter
   / Branson BL20 Quick Connect Bucket to Skidsteer Adapter
So how do you keep the SSQA adapter from popping out?
I put a 3/8 plate at the base which gives me about 60 thousands clearance between the SSQA and the female. My tapered pin is through the female with about 3/4 inch protruding. I put down pressure that was not enough to raise the tires and both of the SSQA adapters popped out from the bottom. The handle didn't release so I presume the tapered pin overcame the spring pressure.
Not good, I can't trust this SSQA connector. Maybe the full tapered pin must protrude to the point past the round rod? I checked online for SSQA failures as previously mentioned, but didnt find much. I might just go back to the Branson/Ansung type mount if there are no satisfactory choices to lock the SSQA in.
   / Branson BL20 Quick Connect Bucket to Skidsteer Adapter #22
The pin needs to go over center:
And have a stop block to prevent the pin from raising when the handles are down:
I installed a stop block and now the pin is positively fixed into the blank tang. Thank you.
   / Branson BL20 Quick Connect Bucket to Skidsteer Adapter #25
Well I finally got my grapple running. I like it and I am learning how to use it. It does seem like every other tool has its specific use, I think I will need a clamshell type as now I do see the benefits of the short tines. This grapple does grab a disorderly load of several 10 inch limbs, not pictured.
Since installing my locking pin stops, there has been no movement. I painted the pins/stops white for easy viewing that they are locked. The handles position does indicate the locked status but for now I want to see it.
I gave the SSQA a real workout yesterday loading decaying matter from the floor of the woods and lifting the tractor while getting a load. I am feeling more confident about the ssqa system.
I never included photo of my 3rd/4th function in this thread. I plan on 90's where the straight connectors are.
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
John Deere 643 Corn Head (A50514)
John Deere 643...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
New 4-17.5 Forerunner Skidloader Tires (A50774)
New 4-17.5...
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
UNUSED AGT H15R EXCAVATOR (A51243)
UNUSED AGT H15R...
