Branson BL20 Quick Connect Bucket to Skidsteer Adapter
   / Branson BL20 Quick Connect Bucket to Skidsteer Adapter
So how do you keep the SSQA adapter from popping out?
I put a 3/8 plate at the base which gives me about 60 thousands clearance between the SSQA and the female. My tapered pin is through the female with about 3/4 inch protruding. I put down pressure that was not enough to raise the tires and both of the SSQA adapters popped out from the bottom. The handle didn't release so I presume the tapered pin overcame the spring pressure.
Not good, I can't trust this SSQA connector. Maybe the full tapered pin must protrude to the point past the round rod? I checked online for SSQA failures as previously mentioned, but didnt find much. I might just go back to the Branson/Ansung type mount if there are no satisfactory choices to lock the SSQA in.
   / Branson BL20 Quick Connect Bucket to Skidsteer Adapter #22
The pin needs to go over center:
And have a stop block to prevent the pin from raising when the handles are down:
I installed a stop block and now the pin is positively fixed into the blank tang. Thank you.
   / Branson BL20 Quick Connect Bucket to Skidsteer Adapter #25
Well I finally got my grapple running. I like it and I am learning how to use it. It does seem like every other tool has its specific use, I think I will need a clamshell type as now I do see the benefits of the short tines. This grapple does grab a disorderly load of several 10 inch limbs, not pictured.
Since installing my locking pin stops, there has been no movement. I painted the pins/stops white for easy viewing that they are locked. The handles position does indicate the locked status but for now I want to see it.
I gave the SSQA a real workout yesterday loading decaying matter from the floor of the woods and lifting the tractor while getting a load. I am feeling more confident about the ssqa system.
I never included photo of my 3rd/4th function in this thread. I plan on 90's where the straight connectors are.
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
2015 PETERBILT CLASS 8 CEMENT MIXER TRUCK (A51243)
2015 PETERBILT...
Handlair 555 Grain Vac (A50514)
Handlair 555 Grain...
UNUSED TOPCAT QUICK ATTACH HYD 4N1 COMBO BUCKET (A51244)
UNUSED TOPCAT...
2000 Trinity Built Trailer (A50514)
2000 Trinity Built...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
