Branson BL20 Quick Connect Bucket to Skidsteer Adapter
   / Branson BL20 Quick Connect Bucket to Skidsteer Adapter
So how do you keep the SSQA adapter from popping out?
I put a 3/8 plate at the base which gives me about 60 thousands clearance between the SSQA and the female. My tapered pin is through the female with about 3/4 inch protruding. I put down pressure that was not enough to raise the tires and both of the SSQA adapters popped out from the bottom. The handle didn't release so I presume the tapered pin overcame the spring pressure.
Not good, I can't trust this SSQA connector. Maybe the full tapered pin must protrude to the point past the round rod? I checked online for SSQA failures as previously mentioned, but didnt find much. I might just go back to the Branson/Ansung type mount if there are no satisfactory choices to lock the SSQA in.
   / Branson BL20 Quick Connect Bucket to Skidsteer Adapter #22
The pin needs to go over center:
And have a stop block to prevent the pin from raising when the handles are down:
I installed a stop block and now the pin is positively fixed into the blank tang. Thank you.
   / Branson BL20 Quick Connect Bucket to Skidsteer Adapter #25
Well I finally got my grapple running. I like it and I am learning how to use it. It does seem like every other tool has its specific use, I think I will need a clamshell type as now I do see the benefits of the short tines. This grapple does grab a disorderly load of several 10 inch limbs, not pictured.
Since installing my locking pin stops, there has been no movement. I painted the pins/stops white for easy viewing that they are locked. The handles position does indicate the locked status but for now I want to see it.
I gave the SSQA a real workout yesterday loading decaying matter from the floor of the woods and lifting the tractor while getting a load. I am feeling more confident about the ssqa system.
I never included photo of my 3rd/4th function in this thread. I plan on 90's where the straight connectors are.
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
2016 JOHN DEERE 35G EXCAVATOR (A51242)
2016 JOHN DEERE...
Crosley 10ft. Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
90018 (A48082)
90018 (A48082)
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
John Deere 10 Shank Chisel Plow (A50515)
John Deere 10...
