Branson 2910i tractor dies while in use.
   / Branson 2910i tractor dies while in use.
2007 Branson 2910i :Engine Kukje : A1400N3-D :3 Cylinder: SERIAL # CN8N00043
Old version tank : Left side part# NTE10100000A0: Right says see comments(this is one I need):
There is new version list part #:
NTE10200000C0. (RH). The old version is no longer manufactured .
We took 5/16” fuel line and put one end in can of fresh diesel (by passing tank) the other end we connected to inlet on lift pump. Tractor started but then acted like it run out of gas and died, this isolated the problem from fuel tank to electrical. Probably where fuel solenoid wire was cut out from burn , it we found to be resister wire. We kept wire and will open it up to try and find some numbers.
Thank you for the help. All suggestions are welcome.
   / Branson 2910i tractor dies while in use. #33
Oh. The one which clearly shows in your post title. Doi!!!
   / Branson 2910i tractor dies while in use. #34
Sally, when you said it dies suddenly it almost sounds like a safety switch or relay problem. When it dies, can you cycle the key switch and it start again?
This is exactly what my Branson tractor is doing. Runs for 15 seconds and then just dies. Cranks right back up. Y
   / Branson 2910i tractor dies while in use. #35
On you fuel filter have you taken the filter out and
checked to see if its clear nothing can be sucked up
in the fuel line?
willy
   / Branson 2910i tractor dies while in use. #36
If you start a new thread on your issue we can help you troubleshoot. Don’t want to derail Sally’s thread.
Have eliminated and now am shipping fuel pump and fuel injectors to be tested and repaired, the last injector wow not working and the other
Oops is veery weak. Going to drop tank and change fuel line while fuel pump and injector are being attended. Will keep you updated. Thanks everyone.
   / Branson 2910i tractor dies while in use. #39
Was this problem ever solved?
2022 KMC 5610 LOT IDENTIFIER 236 (A53084)
2022 KMC 5610 LOT...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
UNUSED FUTURE FI-CL100C HYD CLAMP GRABBER (A51248)
UNUSED FUTURE...
2012 Caterpillar 259B Compact Track Loader Skid Steer (A51691)
2012 Caterpillar...
2022 CASE 580SV BACKHOE (A51246)
2022 CASE 580SV...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
