Brake Light Pic
/ Brake Light Pic #1
Sidewinder
Ball Ground GA
2005 BX23
The picture of the switch has the bracket mounted to it already.
and the switch has three contact poles for wiring, use the outer poles and pic for wiring. Black wire was to battery or ground and red was to accessory wire on fuse block, just tap in with the blue connector. I put connectors on the light to for easy mounting and the light fits real nice on the outer lip of dash by throttle handle. light will work when the key is on only.
/ Brake Light Pic #6
Bob,
This is a great project thanks for taking the time to post it. /forums/images/graemlins/grin.gif
Can you give us technically impaired folks a bit more detail on how you did this? Can you provide details on the parts you used, name and part number, etc. How did you mount it, pictures are a little dark I can not see the detail.
Thanks
New/Unused 20ft Metal Farm Driveway Gate (A65583)
New/Unused 20ft...
2014 Freightliner Cascadia Semi Truck (A66285)
2014 Freightliner...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2022 EZ-GO ELITE...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
We Don't Call 911 Metal Sign (A65583)
We Don't Call 911...
