Boxblade or Scraper Blade?
   / Boxblade or Scraper Blade? #1
babzog
MF 1533
Wondering what the difference is between the two? Why choose one over the other?
   / Boxblade or Scraper Blade? #2
My first three point implement was a rear scraper blade. Given the tasks I needed done, I found it to be rather useless. Got rid of it in favor of a box blade and a landscape rake. Never regretted the decision
//greg//
   / Boxblade or Scraper Blade? #3
A scraper blade can generally be angled while a box blade cannot. A scraper blade can divert material to one side or the other which may be useful if you need this. A box blade is better at moving quantities of material from one location to another. A box blade usually has scarifiers also in addition to a rear cutting edge and an angle blade does not. Hope this helps.
   / Boxblade or Scraper Blade? #4
Of course each one is designed for different uses,but what I like about the boxblade is I also use mine for some rear ballast.
Boxblade and bushhog are attachments I most have on my tractor.
Different areas of world different attachments of course.
Boone
   / Boxblade or Scraper Blade? #5
Best of all: Grading scraper! (see my signature)
IMHO of course.
   / Boxblade or Scraper Blade? #6
Welcome to TBN !!!
You are opening a can of worms. But that is OK, that is what TBNers like. You will get many opinions of which one is best.
I think the difference between the two depends a great deal on the operator and their skill with either or both impliments. There is a lot of overlap in the functionality of both impliments.
My take on it is that a scraper blade moves the cut material across or along the blade distributing material in low spots under the blade and piling the excess in a berm as it comes of the end of the blade in typical road grader fashion. So if you hold the blade in a fixed plane as you travel forward you will cut and fill to get a flat surface with the excess material piled on the side. The hard part is holding the blade in a fixed plane. It takes practice. So the scraper moves material across the line of travel.
The box blade also cuts and distributes material along and under the blade in the low spots but the excess material is trapped in the box. This allows you to drag it long distances. You can lift the blade and let it out where you want it. It is harder to cut a flat plane because of the trapped material but it is easier to use than a rear blade if you just want to follow the contour you already have. This is because you can let it ride on the reversed second blade along the existing contour. So the box blade moves material along the line of travel as opposed to across.
This is an over simplification as there are loads of things you can do with each or either.
For the road work I do I prefer the rear blade for the most part.
   / Boxblade or Scraper Blade? #7
i can't think anything different than what others have already said.
so will take a different approach.
what are your projects / goals to have done?
rock / gravel drive way?
plowing snow?
landscaping (leveling out the yard?)
many other uses....
below website, has a good amount of attachments and details about them along with videos for a good amount of attachments.
everythingattachments
Everything Attachments | Skid Steer Attachments, Tractor Attachments, 3 Point Hitch Attachments, and Farm Tractor Implements.
   / Boxblade or Scraper Blade? #8
//greg//
That is my combo too.
Okay, so if what I want to do is move gravel that's blown off to the side of the driveway or cut down the center hump in the driveway and re-contour the surface, fill in the odd pothole, then a scraper blade sounds like the tool I'd want.
   / Boxblade or Scraper Blade? #10
When I was as the same stage as you, I initially bought a box blade because the project I needed to work on was to dig some sediment out of a dried up pond. I use the box blade for several things including ballast, but the main thing I use it for is working on the gravel drive way. For pot hole repair, you really need to put the scarficers down and loosen the rock up some and then smooth it back out. If you just pull some rock onto the pot hole, you will soon have the pot hole back again. You can crown the driveway by lowering one side of the box blade and go down one side and back up the other and it will move the rock toward the center of the drive. The key to using it is understanding that if you lenthen the top link it will not dig as much and will tend to smooth it out. Shortening the top link causes it to dig down so you can move more material.
The first year I had it, I tried using it with the FEL to clear snow. Fortunately we did not get much snow that year as it was not very effective for that. The next summer I found a dealer going out of business who had some rear blades (scrapers) he was getting rid of. I bought one that will angle and tilt. I use it to dig trenches to bury the drain pipe from the down spouts, push the dirt back into the trenches, but mainly to plow snow. This weekend I will probably put it on the back of the tractor an it will stay there all winter.
Unfortunately they are two different tools. Each can somewhat substitute for the other, but not entirely. If we got no snow, I wouldn't have bought the rear blade but to each their own.
   / Boxblade or Scraper Blade? #11
You'll be very disappointed.
I predict that - with a conventional scraper blade - you'll tear up the side of the road, and end up scraping in more dirt/grass/weeds than you will errant gravel. That's a job for a landscape rake.
Further, you'll become extremely frustrated watching a conventional scraper blade bounce up and down on the center hump. That's a job for a box blade.
//greg//
   / Boxblade or Scraper Blade? #12
//greg//
I agree, If whatever it is you plan on working is already established a good landscape rake will be much more effective (especially on gravel) and will not make more work for you like scrape blades and box blades.
If you have a lot of earth to move the box blade is the ticket.
Regardles of the implement (box blade, rake or scrape blade) a hydraulic top link will make them all more efffective and easier to use.
   / Boxblade or Scraper Blade? #13
Unlike KU, I like having my heavy Gannon box on the back for snowplowing. I have an old PA truck plow on the loader, but the box is good for pulling away from the barn doors, parked cars, etc. You can push snow with it too, if you're crossways between snowbanks at the end of a driveway. It's heavy, too, to balance the front contraption.
Jim
   / Boxblade or Scraper Blade? #14
Yes. Typical dirt/gravel road maintenance procedure is to run the edge of the road with a blade angled toward the middle, so you are pushing material toward the middle. It digs in better than a rake, so you churn up both dirt and stones and get them mixing. If the road is fairly hard, a rake will just pop out the surface rocks and do nothing else. You then run the crown material back down to shape and groom the road. You can do it all with just a blade, but you are really going to want a rake (with gauge wheels) to finish it off.
Incidentally, gravel that has blown off to the side of the road becomes culvert material. Getting it back onto the drive in any usable fashion is generally impossible.
JayC
   / Boxblade or Scraper Blade? #15
//greg//
I agree, a back blade typically is longer and telegraphs more of the up and down of the front end.
Yes. Typical dirt/gravel road maintenance procedure is to run the edge of the road with a blade angled toward the middle, so you are pushing material toward the middle. It digs in better than a rake, so you churn up both dirt and stones and get them mixing. If the road is fairly hard, a rake will just pop out the surface rocks and do nothing else. You then run the crown material back down to shape and groom the road. You can do it all with just a blade, but you are really going to want a rake (with gauge wheels) to finish it off. Much easier after a rain as well.
Incidentally, gravel that has blown off to the side of the road becomes culvert material. Getting it back onto the drive in any usable fashion is generally impossible. Yup!
JayC
When I was as the same stage as you, I initially bought a box blade because the project I needed to work on was to dig some sediment out of a dried up pond. I use the box blade for several things including ballast, but the main thing I use it for is working on the gravel drive way. For pot hole repair, you really need to put the scarficers down and loosen the rock up some and then smooth it back out. If you just pull some rock onto the pot hole, you will soon have the pot hole back again. You can crown the driveway by lowering one side of the box blade and go down one side and back up the other and it will move the rock toward the center of the drive. The key to using it is understanding that if you lenthen the top link it will not dig as much and will tend to smooth it out. Shortening the top link causes it to dig down so you can move more material. This is where a hydraulic top-link comes in handy.
Unfortunately they are two different tools. Each can somewhat substitute for the other, but not entirely. Therein lies the dilemma If we got no snow, I wouldn't have bought the rear blade but to each their own.
I use a rear blade for snow as well but cut out 2' in length which put the blade much closer to the rear wheels but still allows 2 holes either way of center for angling the snow off to the side.
I am reluctant to steer you either way. Personally after having used both I prefer the box blade but I do have top and tilt on my tractor. I do like the shorter length of the box blade and the dual cutting edges. In the winter I use the rear blade in heavy snow on the big tractor and the box blade on the little one for the quick cleanup jobs. I plan on using a 6' snow blade on both loaders this year but make it compatible Q/A wise. I'll post some pics when I finish that project.
   / Boxblade or Scraper Blade? #16
I have landscape rake and box blade. I put a "wing" on the box blade for snow cleaning. It increases its width for about 2 ft on one side. After the experience I will add another wing on the other side.
I am also considering attaching a piece of about 2 ft wide conveyor belt or similar material to the rake such a way that it will extend the rake on each side and use it for snow cleaning and scraping mud from concrete in front of the house and the shop.
   / Boxblade or Scraper Blade? #17
I have a rear blade and a box blade, the rear blade is indispensable for snow removal especially on hard surfaces. But that's the only thing I use it for. Tried cutting some drainage swales with the rear blade and made such a mess in such a short time.
Put the box scraper on and made perfect smooth level cuts. I always tell people the box scrapper is very "forgiving", as it self levels as it goes, filling low spots and cutting high spots. definitely less skill required for using the box blade IMO.
JB
All good thoughts, gentlemen. Please, keep them coming.
When I say "gravel that's blown off to the side", I don't mean much further than 12 - 18" from the wheel ruts.
No rear hydraulics on my 1533 so all adjustments are going to be manually done.
How would the box blade move material from the side to the center seeing as how the blade is straight? I would have thought the blade would have to be angled back in order to move material in that direction. As well, why would the box blade be less likely to skip/bounce over the center hump vs a scraper blade?
   / Boxblade or Scraper Blade? #19
I don't think you'd regret having both, especially if you clear snow. My reg duty 7' blade is about 320 lbs. The reg duty 6' box blade I'm getting this weekend is about 520lbs and has steeper blade angles to cut into material, plus the scarifiers to really rip into stuff and shouldn't skip over much I hope.
So with reg duty blades of both types to redo my driveway, I'd rip it up and level with boxblade and crown with the grader blade. If I had a 1000lb+ grader blade then I'd skip the box blade altogether for that job but still need a box blade to move dirt and the scarifiers to rip into turf.
I found a used back blade for half of new, but used box blades seem to go for only $100-150 off of new prices in my area for some reason so I'm getting a new one.
   / Boxblade or Scraper Blade? #20
We're referring to the hydraulic controls of the rear hitch; position and/or draft
Hence the boxblade/landscape rake combo. Indexed rake brings it in from the edges, boxblade cuts down the center hump. Either one can spread the loosened material
Weight and design.
//greg//
2020 Deere 50G (A53317)
2020 Deere 50G...
Nissan Forklift (A55973)
Nissan Forklift...
2003 FORD F150 HARLEY DAVIDSON EDITION PICKUP TRUCK (A59905)
2003 FORD F150...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
