Box Scraper Box scrapper questions
/ Box scrapper questions #1
azop
Bronze Member
I purchased a 72 inch Bobcat box blade for my CT230...the owners manual for the box blade doesn't contain anything useful for how to actually level it.
Should it be level along the rear of the box blade when it's lifted up off the ground?
Should the box blade be level from the front rails (where the shanks are) to the back rails, or should it be tilted forward (towards the shanks) or back (towards the rear blades)?
Thanks!
/ Box scrapper questions #2
I just set ours up by adjusting the top link and the right adjustable lift arm on the tractor. Our HD Bushhog 84" box blade has NO adjustments on it. How I have it adjusted depends on the task at hand.
/ Box scrapper questions #3
About your scraper;
When an integral implement needs to be leveled
it is always done from side to side.
Assuming you have the right lower link with the crank it
allows the right lower link to drop farther in the furrow
and allow the toe of the plow to be as deep as possible
in the furrow when the hand crank is used to extend
the right lower link fully.
The hand crank should bring the right lower link all the
way in and equal to the left lower links mounting eye bearing.
The top link also allows you to follow the ground contours easier
as it permits the implement to roll foward and back following the
slope of the ground when using a mower.
When using a ridgid implement you want the top link adjusted tight and maintaining level from front to back on the implement like your box scraper.
You need to be more concerned about the depth adjustment of the ripping teeth as you will tear up a huge amount of material when working the ground.
/ Box scrapper questions #4
I believe (I am a new box blade owner too,..) you tilt the BB forward towards the shanks to get more shank bite into the ground. you tilt it back to lessen the shank bite. Tipping it further back will make the blade scrape more.
This is only based on what I have read. I have yet to use my BB yet
Okay thanks. What is a easy way to adjust the top link? It's pretty hard to move it with the weight of the box blade
/ Box scrapper questions #6
Remove the top link from the tractor, unwind each threaded end all the way and wire brush the threads to get them clean. Rub the threads with a coating of axle grease, then screw the end pieces back into the center portion, make sure both ends are wound in all the way. Attach one end to the tractor and hold the other end from turning, now turn the center section only to lengthen the entire top link until the holes line up with the implement.
Pin it to the implement.
Lower the implement to the ground and adjust the center section to adjust the attitude of the implement to level. On a small tractor this should turn easily enough but to answer your question sometimes to lengthen the top link it helps to pick up the implement slightly. To shorten the top link and pitch the boxblade forward you can pull the implement while on the ground to make it lean forwards slightly making the top link easier to turn and shorten.
/ Box scrapper questions #7
Dont hesitate to douse the threads and the crank with fluid film!!!:thumbsup:
Is fluid film WD40?
/ Box scrapper questions #10
What jenkinsph said so well. As to proper "leveling", as mentioned, it depends on what you want to do as tilting forward will make it dig more and back works better for smoothing/leveling. Level works well for simply moving loose material.
I finally got tired of fooling with climbing on and off the tractor and now use a hydraulic top link.
/ Box scrapper questions #12
Lower your BB down all the way, make your adjustments to your top link until it gets hard to turn, then lift the BB then lower it again. You may have to do that a couple of times depending on how much you are adjusting it.
The is a good video provided by Everythingattachments.com on how to use a BB. It shows the different uses for a BB, just go to their website and click on boxblades on the left side and the vidoe is at the bottom of the page I think.
2000 PETERBILT 378(INOPERABLE) (A67714)
2000 PETERBILT...
2012 FREIGHTLINER CASCADIA 125 6X4 TANDEM  SLEEPER TRUCK TRACTOR (A69167)
2012 FREIGHTLINER...
15-19.5 Tire and Wheel (A68134)
15-19.5 Tire and...
2015 John Deere 319E Compact Track Loader Skid Steer (A66734)
2015 John Deere...
PAIR OF FRAC TANK STANDS (A68842)
PAIR OF FRAC TANK...
2014 CATERPILLAR 320EL RR EXCAVATOR (A65056)
2014 CATERPILLAR...
