Box Scraper Box blade size for small tractor
/ Box blade size for small tractor #1
sroys
Hi,
This might have been covered in other posts, but I couldn't find much that would help me.
I just bought a small 13hp Ford 1300 tractor and was wondering what size box blade would be the best, or even if the tractor is powerful enough to even think of a box blade. I'm not worried about moving lots of dirt fast, but I have an area about 30'x60' that I'd like to level out, and a long gravel driveway that has a few low spots.
Thanks,
Steve
/ Box blade size for small tractor #2
4' Should be fine, if a light-duty unit...
/ Box blade size for small tractor #3
I agree.. 4' should do a good job covering the rer tires..
soundguy
So, 4' would be good. However, there's a 5' box blade on Craig's list for a decent price. Would that be too much attachment for my little 1300?
/ Box blade size for small tractor #5
I think you won't have enough traction for it..
soundguy
/ Box blade size for small tractor #6
I also think the 5 footer will be too large for your tractor. Good Luck :p
Troy
/ Box blade size for small tractor #7
I have a 5' behind my sc2400 ccyanmar and its all it really wants
I dont think your lil ford is going to pull it
Thanks for all of your sage advice. It seems that the general consensus is that I need a bigger tractor, so now all I have to do is convince my wife... :)
/ Box blade size for small tractor #9
I would not say that; I would say you need the smaller of the two box blades! Now if you are looking for an excuse to get a bigger tractor, well then.......:p
Troy
/ Box blade size for small tractor #10
i have a light weight 5'
It likes to skip over hard ground. But in softer ground or if i put some ripper shanks down i can EASLY bring my "much" larger TC33 to a standstill in no time.
/ Box blade size for small tractor #11
I had a Ford 1100 4x4 and built a 5' boxblade out of 10" I-beam. It was great for moving piles of dirt, etc but was lacking in the area when it came to moving fresh dirt, meaning dirt that had never been tilled. I had enough traction, with fwa, so that wasn't a problem, but if I had to purchase a new one, it would be just wide enough to cover the wheel tracks when they are set inwards, or 4' whichever is greater.
David from jax
/ Box blade size for small tractor #12
I have the 2 wheel drive Ford 1100 and a medium-duty 4 foot box blade. The blade will easily stop the tractor, even with 80 lbs of wheel weight per rear wheel. Obviously I need either more wheel weight...or a heavier tractor...as well as something other than turf tires.
Other than that, though, the 4 foot width is perfect.
3146 (A63117)
3146 (A63117)
2022 CATERPILLAR 299D3 SKID STEER (A65056)
2022 CATERPILLAR...
1994 KENWORTH T600 (A67714)
1994 KENWORTH T600...
2012 Volkswagen Passat (A66738)
2012 Volkswagen...
2018 32ft Forest River Lacrosse 3211RK T/A Travel Trailer (A66738)
2018 32ft Forest...
LEEBOY 8515B PAVER (A67714)
LEEBOY 8515B PAVER...
