Bought a Carry All
/ Bought a Carry All #1
man00
eastern ok
kubota
thinking about making some type of hauler for a ballast..Anyone on here tried that with one?
/ Bought a Carry All #2
no, but be careful and check theweight rating. the one i have and others i've seen don't carry much on the bottom forks, so a ballast would need to be supported by the vertical portion.
Think I will return mine to TSC, wouldn't hook up with my QH (SpeeCo). Tired that QH top link adapter thing it was a no go also, I don't want to have to grind/weld to make it work. No big deal, I will have a ballast box made local or maybe order one from titan.
/ Bought a Carry All #4
You could get rear pallet forks. Much more useful and heavy duty. That's my plan eventually, then I can make an easily removable ballast (though it'll stick out a bit more than some)
/ Bought a Carry All #5
Purchased my Carry-All at Tractor Supply and it works with my Harbor Freight Quick Hitch. Is the SpeeCo that much different?
I don't know if they different or not. Hook on QH would hit top of the carry all, bottom pins were not installed at the same distance from top pin. I think I just got one that shouldn't have made it through quality control. I called Tarter ( the ones who make it) they said to return it and try another. Tried the QH top link adapter another no go. I sorta lost interest after that and decided to go another way.
/ Bought a Carry All #7
First thing I did when I got my QHs was to weld a 1.5-2" extension to the back of the top hook & re-drill the holes. That way the hook sticks out further. Not enough clearance on the top hook is a common problem with many implements & easily fixed.
/ Bought a Carry All #8
I have both a carry-all and ballast box. Use the carry-all all the time but very seldom use the ballast box. When I need some quick extra rear weight I just throw some sand bags on the carry-all.
I tried the top link adapter bracket and it didn't work either. I have since returned it to TSC, I didn't want to mess with it
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
Cow Skull Decoration (A64127)
Cow Skull...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2021 Deere 35G (A64126)
2021 Deere 35G...
Pallet of Misc Sling Webbings (A64127)
Pallet of Misc...
