Boomer 35 worklight install
/ Boomer 35 worklight install
Might this be it ? 18 JUMPER,765mm L JUMPER, Worklight 84360959 $32.08
BOOMER 35 - COMPACT TRACTOR 12X12 OR HST 8/10- | Messick's
this is essentially an extension cable to connect to the tractor bullet connectors on the tractor. The light I'm using (ROPSlight.com) is
the same but the bullet ends are separate male/female ends. I'm just not able to find the tractor harness ends to connect this onto.
The NH dealer local could not help. The wiring schematic just lists that there is a Yellow+Red and Black set of wires to connect to
but doesn't say where they are. More hunt'in and peck'in I guess...
thx.
well, this is embarrasing....the 2 wires behind the trailer plug (Yellow with red stripe and black one) ARE in fact the correct wires....the reason the work light wasn't firing up is cuz the damned rear work light doesn't get power until you actually start the tractor. curiously, the front lights work with the key off and turning the switch to the work light position.
so, I'm good to go.
thx.
Wendell
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
GROVE RT 63S HEAVY DUTY HYDRAULIC CRANE (A60736)
GROVE RT 63S HEAVY...
2016 GMC Sierra 1500 Crew Cab Pickup Truck (A59230)
2016 GMC Sierra...
excavator trenching bucket- one bucket per lot (A61307)
excavator...
Deere 350G LC (A53317)
