Boomer 35 worklight install
/ Boomer 35 worklight install #1
mackendw
Cornwall, PE
New Holland TZ25DA
bought a new LED worklight for my boomer 35 tractor (HST). I have it mounted to the ROPS and switch attached.
Does anyone know where the tie-in plugs (2) for the 2 wire clip connectors are located on the rear? I found 2 wires
along the back wiring channel behind the seat (black and yellow) but they are not the ones. There are another pair
running out of the same black tube that connect up to the gas tank presumably to measure fuel level. I looked up
under both fenders and the wire bundle underneath just connects into the signal lights. No loose wire theres.
The light never came on with the switch when I turned the dash switch to work light position (front light came on)
when I tried the black / yellow pair above with the LED light.
Only have the user manual and no electrical diagram to go by...
thx. for any insight.
W. MacKenzie
/ Boomer 35 worklight install #2
Could the light you added be sensitive to polarity, and you had it backwards when you tryed it? Swap the wires and try it, might work. Otherwise, test it with a volt meter or test light.
tried it swapped and nothing either. put a volt meter on the plug connectors on the tractor and the connections are good. ie: the meter goes hot to right on
connection. I wonder how I can determine if it's the light. Could you hook the light up to a battery to test it out? 12V as in a lawn mower battery?
/ Boomer 35 worklight install #4
Yes you can wire it directly to a battery for testing.
Just tested the LED light and switch with my lawn tractor 12V battery. Works fine. so, I obviously don't have the right wires on the tractor.
/ Boomer 35 worklight install #6
On my NH 1925, and NH 2310, each had an unused 2 pole connector under the seat (looks like 1/2 of a 4 prong trailer plug). The 1925 was unmarked and teh TC2310 said Work Light). One pole was 12V positive. I wired that to a switch, and then to a light. I found a mating 2 pole plug at my local auto auto parts store.
I "think" I found it under the plate covering the hydraulic lift/lower lever on the right side of the driver seat. The wire bundle going to the rear lights comes out from there
also. Is there a name for this type of connector?
The plug under the hydraulic lift lever plate where the rear light wiring bundle comes out from a rubber grommet plug has this rectangular white plug with 2 flat connectors on it with each in different directions ie: one is --, the other | if you know what I mean. I have a query into my local NH dealer to get more info/exact info on where the work light connector is supposed to be. Will update the thread if they respond with anything useful.
Here is an image of what the plug/connector looks like:
/ Boomer 35 worklight install #10
Might this be it ? 18 JUMPER,765mm L JUMPER, Worklight 84360959 $32.08
BOOMER 35 - COMPACT TRACTOR 12X12 OR HST 8/10- | Messick's
this is essentially an extension cable to connect to the tractor bullet connectors on the tractor. The light I'm using (ROPSlight.com) is
the same but the bullet ends are separate male/female ends. I'm just not able to find the tractor harness ends to connect this onto.
The NH dealer local could not help. The wiring schematic just lists that there is a Yellow+Red and Black set of wires to connect to
but doesn't say where they are. More hunt'in and peck'in I guess...
thx.
well, this is embarrasing....the 2 wires behind the trailer plug (Yellow with red stripe and black one) ARE in fact the correct wires....the reason the work light wasn't firing up is cuz the damned rear work light doesn't get power until you actually start the tractor. curiously, the front lights work with the key off and turning the switch to the work light position.
so, I'm good to go.
thx.
Wendell
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
3268 (A63117)
3268 (A63117)
Jack Daniels Sign (A64557)
Jack Daniels Sign...
Tow arm attachment (A64194)
Tow arm attachment...
2011 Caterpillar 420E 4x4 Extendahoe Loader Backhoe (A64194)
2011 Caterpillar...
(INOP) 2022 MACK MD6 WATER TRUCK (A65054)
(INOP) 2022 MACK...
