Boiling fluid
/ Boiling fluid #1
ch1ch2
DFW, TX
IH 584, NH TC33DA, NH TN95A
I was doing some light shredding yesterday. Low RPM 1K TO 2K. Several stops to cut mesquite trees, and push big rocks. After about four hours work, I stopped and heard the hydraulic fluid boiling in the transmission. It continued to boil for about a minute after I stopped.
I checked the level. It was low but on the stick.
Any Ideas why this happened? Anything I need to fix. I plan on changing the fluid. Anything I need do do different?
/ Boiling fluid #2
Running at a low rpm causes the engine and hydraulics to work harder. Hydraulics work best at high rpms. That increases flow and cooling.
There also could be a restriction in the hyd. line. This forces the fluid through a restriction causing more friction which increases temp..
You may have damaged some seals with the high temp. Keep an eye out for leaks.
Check your cooling fan for damage.
/ Boiling fluid
Thanks. That makes sense about the low RPM. I had assumed low RPM would be better. I understand how I was wrong.
I got in late yesterday and have not had a chance to check anything mechanical. I am planning on doing that before changing the fluid today.
/ Boiling fluid #5
I'll bet tractor has an oil cooler. Check to see if it needs cleaning.
/ Boiling fluid #6
might of had a valve closed and oil was going thru the relief valve all that time.
/ Boiling fluid
OK thanks for all the input.
Just got back in town.
I changed the fluid. 5 gallons came out of a 9 gallon system. 6 gallons went back in to top it off. I will change it again "soon". The fluid had not been changed in 5 years with only 26 hours on it. The fluid looks contaminated. Strains of two or three colors. Brown and gray and milk.
Radiator is full. No problem there. There was probably condensation contamination over five years. Some leakage from the FEL but I would not think enough to be a gallon low. Maybe so over the years.
I will check the oil cooler.
No relief valve noise. How else might I check?
The alternator was loose. Maybe the fan was slipping also contributing to the cooling problem,but the engine was not running hot.
/ Boiling fluid #8
Did you use the old oil? Not sure what you meant by 5 gal. came out and 6 went in for a 9 gal. system.
Also, with the oil looking brown, gray and milky I would guess condensation was forming inside. Low fluid level would cause high temp too.
/ Boiling fluid
That's funny.
No disrespect intended. I guess there might be someone who would reuse old oil.
You put a smile on my face.
The measurement of oil is indicative of how much did not drain out. Or, how much contaminated oil remained in the system. 1/3 of system capacity did not drain. That does not seem like a good thing. I do not think that is as designed.
The filter was fairly new with not many hours. I did not change it. I will change it with the next oil change. Base on the hours vs time; I guess it will be 5 hours or no more than 1 year which ever comes first. This is one of three tractor and it rarely gets used. At close to $200 to change all the oils and filters, it gets to be very expensive to justify at only 5 hours a year. It is still cheaper and more convenient than renting.
/ Boiling fluid #10
ch1ch2.
There may be a second drain plug to get to the remaining oil. If running only a few hours per year condensation may be an ongoing problem.
/ Boiling fluid
Yes I pulled two drain plugs.
Thanks
/ Boiling fluid #12
You will never get the full 9 gal out of a 9 gal system. Some of the 3 gals left is in the hoses, cylinders and small cavities in my opinion.
/ Boiling fluid #13
Ditto fluid capacities listed are for dry compartments/components which once filled up to spec's are very difficult to get totally dry again.
/ Boiling fluid #14
That's funny.
It sounds like you had a considerable amount of water in the oil and if your filter had a cellulose filtering medium the water will swell the paper and make it highly restrictive to flow and if water contaminates the oil, it will form sludge that will rapidly plug a filter element.
/ Boiling fluid
I just changed the filter the week before.
New fluid and I put it pack to work. Bad news..It started boiling again after about 15 minutes of running the shredder. I quit shredding and just used the FEL for the next 4 hours moving dirt with no problem. Why would the PTO cause the fluid to boil?
/ Boiling fluid #16
It might not have anything to do with PTO but three point hitch or remote hydraulic is turned on. Just guessing?
/ Boiling fluid #17
ch1ch2
What brand & model tractor? If the tractor in question has a hyd engaged pto then pto clutch or valve could be causing the hot hyd oil.
/ Boiling fluid
It is a IH 584.
Can you explain. I am a retired mechanic but I am not familiar with the mechanics involved.
/ Boiling fluid #19
I'll have to do some research on IH 584 but I'll bet the pto is hydraulically controlled. If valve or seals on hyd controlled clutch are leaking that can cause hyd oil to heat.
2008 Chevrolet Silverado Pickup Truck (A62613)
2008 Chevrolet...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2017 Chevrolet Sonic Hatchback (A61574)
2017 Chevrolet...
GMC C7500 (A64127)
GMC C7500 (A64127)
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
