Traction Bobcat travel problem
/ Bobcat travel problem #1
tylertown
MS
Massey Ferguson 40 backhoe, Ford 5000 general purpose
Hi my name is Tyler, im a new member to this site and was hoping I could get some experienced info on a issue of mine with my bobcat 331. here goes, my machine is a 99 bobcat 331 and haven't owned the machine very long but no major problems the only thing wrong with it is i have a slight hydraulic leak at the base of the boom coming from the cluster of hoses. but my main concern is the travel part of the machine. when i press both levers to move the machine forward or in reverse it tends to act like the left travel motor may be weaker than the right. it wants to pull slightly to the left... but when i engage the machine into high gear for faster travel everything is fine and the problem no longer exists... what might cause this??? please help.
/ Bobcat travel problem #2
This should have been posted in Bobcat Construction Equipment so don't be surprised if it gets moved.
There are several possibilities that could cause this, most require pressure gauges, special test fittings, and schematic of the system to check properly. But there is one easy check to make. Look on your gear pump at back of the engine, there are 3 gear pump sections and between the middle outlet section and the end section there is a square block with 2 hex plugs, these are check valves. First make sure 1 of those is not leaking (fix it needed), remove both and swap them, putting back in opposite holes. Try operating and see if the right side motor seems weaker. If so replace them both.
In low range the middle pump feeds the right motor and end pump feeds the left and both check valves are closed. When in high range the front pump sends oil through these check valves to feed both pumps, so a check valve not seated tight could cause your problem.
thanks a lot!! I am about to try this
one more thing too... my left travel stick is tighter than the left. could this be because a previous owner tried to adjust it or is it adjustable like that?
/ Bobcat travel problem #5
Travel control is system of mechanical linkage with ball joints and adjustable rods. Check for lubrication and wear on all the linkage for both levers. If the controls don't move same amount freely, that may be your drive problem..
ok thanks a lot!! great information!
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2022 EZ-GO ELITE...
John Deere 2210 Field Cultivator 43' (A63688)
John Deere 2210...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
2001 Ford E-450 Super Duty 14ft. Box Truck (A61573)
2001 Ford E-450...
GMC 2500HD 4wd Service Truck (A63689)
GMC 2500HD 4wd...
