Big tractor syndrome
/ Big tractor syndrome #161
Once again, I still have not seen any bias against the BX.
Most people simply would want a larger machine for 13 acres. Including me.
If you are happy with it, That's great.
I personally would want bigger. The end.
/ Big tractor syndrome #162
My answer has always been to the problem is get two I don't see how anyone can get by with only one tractor,
/ Big tractor syndrome #163
I find 3 to be perfect for me.
/ Big tractor syndrome #164
I could not have said it any better.
/ Big tractor syndrome #166
I had 2 tractors. One rarely got used any more. So I sold it.
I now have 1 tractor and 1 zero turn = perfect.
/ Big tractor syndrome #167
Haven't read all 17 pages, so, there. I think people would be surprised with what you can accomplish with a Ford 8n/NAA with the right attachments and attitude. I cleaned out a tank (pond or dirt pond for those east of the Mississippi and north of Tulsa) with an NAA using a chisel, a back blade, and, a rear bucket years ago. Took a week but it got done at the fraction of hiring a dozer.
My dad does just about everything he needs done on a 1000 acre ranch with a 2710 Kubota. Dirt work, spraying, shredding. Now, he's retired and has nothing but time but he gets it done. I've operated some 90hp tractors that would do just about anything another 120hp tractor I ran would do (both MF.)
/ Big tractor syndrome #168
I don't have a BX but I sure would like to. I stopped at 11 tractors, but have thought about making it an even dozen.
/ Big tractor syndrome #169
Having owned an 8N, I wouldn't be surprised at what you can get done with one, but the reality is, I cost as much per day as a dozer does, so it wouldn't save me a penny.
I can make more money, but I'm having zero luck making more time. :(
With that said, I'd love to have a BX around here for small chores.
/ Big tractor syndrome #170
JoeinTX;3720560. Took a week but it got done at the fraction of hiring a dozer. My dad does just about everything he needs done on a 1000 acre ranch with a 2710 Kubota. Dirt work said:
There is the answer! Took a week!!!!
I don't have anything against the smaller units. As many others here I would certainly add one to my arsenal if I could right now. BUT on the same note I know the limits compared to other machines. As I stated before I have run them many times and some of that work was the same chores I performed both with my big machine and my 755 which is similar in HP but bigger physically.
So here goes.
Deep snow the BX got stuck and couldn't push the snow banks back to make room for more.
When digging some rather large holes to plant 6 huge trees my neighbor purchased off of me when I got a good deal on a large quantity the BX took all day and the job still wasn't done. I had to go finish the last hole for him with my machine and he was astonished at how quickly I did it Then he tried pushing the huge trees into the holes but couldn't budge them with the BX. But even with a small HP like the JD has it was able to push those big trees right into the holes without any problem. He tried to use my tiller once but ended up having to borrow my machine as well because he couldn't pull the tiller threw the field with any confidence or at a reasonable pace and was struggling for traction on all the uphill slopes. The taller more aggressive stance and tires that would not let the machine bottom out made short work of it again. You posted a vid of yourself towing out a supposedly stuck delivery truck that I could have pulled out with a lawn mower that dosnt even have 4 wheel drive but I ask will it pull that tuck out when its buried down to the axel in mud or will it be able to get enough traction to pull a truck out of the snow bank without digging around it for an hour first?
Add up the time it takes to do a given job. Then figure how much less time it would take to do the same job with a bigger machine. Each time you do so record that amount and see how quickly the smaller machine becomes more costly in the long run. Also take into consideration the wear factor. Yes it will wear much faster working longer hours to do the same task, this is fact and no one with a mechanical aptitude could make any other reasonable argument against it. My JD has worn itself out doing jobs that were just too big for it over time but that old international is still doing the heavy work with ease and will be a good buy for someone when I sell it later this year and its twice as old as the smaller JD. I only wish I could have had it here to do all the heavy work I struggled to get done with the JD. But transport of a machine of its size back and forth from Job sites and other properties is a costly endeavor so I struggled with some jobs that now I wont have to with the new machine.
No bigger isn't always better depending on the persons usage and desire for taking on different tasks but many of us here just like to keep adding to our list of ever changing Ideas and for many they don't get easy as the list grows but instead harder and more time consuming each and every time. I figure in an other 10 years I might be able to sell off anything bigger than a BX and then only have light work for maintaining the property but for now My money and time is much better spent on a bigger machine that dosnt struggle or take all day to get the same results that I can obtain in less than half the time!
Again good luck with your new machine, I hope it is all you will ever need but please stop trying to tout it as the cure all for its not even close! The reason I have a Cat, international, JD, Kioti and a lawn mower is much too obvious to those of us who have been around.
Again congats on your new machine!
/ Big tractor syndrome #171
There is no accounting for one's experience with a machine and knowing what you can do with it. Only time and practice. We see a lot of people here on this board, new to tractors or land owning, who come here wanting to know what tractor they need to till their garden or cut a pasture or to hobby hay farm. No idea and the answers can be far and wide. Do I need 30hp or 40hp or 50hp? I don't know, what do you know about tractors or implements? What's the time frame? For profit or fun? There is no "right" answer often times. You can move a mountain with a 40 horse tractor or a D11 Cat but the defining criteria is when you want it done by. How much should I spend? Can't tell you. How much do you have to spend and do you know what you're spending it on?
/ Big tractor syndrome #174
I also think some of the conflict of opinion here is experience on this website. It's common to see new members be very confrontational in their approach. Often taking offense at everything that's said against their opinion. As time goes by most of us mellow. We understand that it's not personal. It's simply a difference of approach to the same topic.
Cherokee's responses tend to have a degrading slant to them. I don't believe he means to sound that way. I also believe that tone will change with time.
I can name others that started the same way. And now they have gotten accustomed to the tone on this forum and have moderated. I'm sure when I started here I was considered the same way. Fortunately the oldtimers were patient with me and now we are great friends.
/ Big tractor syndrome #175
I suspect the problem is that Cherokee decided at the out set that he was being up sold in tractor size without the need for it. Most experienced tractor owners/operators don't have to ask what size tractor is needed for a given job. Most of the experienced people are interested in hearing about the slight differences between brands and models and the cost.
Without experience well it is a crapshoot, you think you know what you need, you buy what you think you need, you defend what you bought. If you stick around and keep up with the forum, use your tractor for a few years you start to gain some experience.
/ Big tractor syndrome #176
I hope you are right, but I can remember quite a few who burned a lot of bridges and are long gone. You've been around a lot longer than I, so I don't know what you were like, but I doubt you were remotely like this, I sure as heck hope I wasn't. Now, I've pointed out many things about which I have changed my mind, but I've always tried to respectful and refrained from denigrating the advice or experience of others and that can be hard at times.
/ Big tractor syndrome #177
Sometimes I still get a little arrogant. Murph and James keep me in check....... I use you as a barometer sometimes as well Larry. :D
/ Big tractor syndrome #178
I got me eye on ya!:cool::eek::dance1: Its all good!
/ Big tractor syndrome #179
We are all looking out for you Richard:)
/ Big tractor syndrome #180
And I truly need it and appreciate it my friends. :D
2011 Ford F-350 Service Truck (A62613)
2011 Ford F-350...
2019 Kubota KX057-4 (A64126)
2019 Kubota...
PREVIEW DATES AND TIMES (A65583)
PREVIEW DATES AND...
2006 Kawasaki Bayou 250 (A64127)
2006 Kawasaki...
Caterpillar 289D (A64126)
Caterpillar 289D...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
