Box Scraper BIg Ox Rollover Box Scraper
/ BIg Ox Rollover Box Scraper #1
DingoA7X
Spring Creek, NV
Kubota L3240, Jinma 284
Hi Guys:
I am new to the forum, and just bought a 72 inch Big Ox Rollover Box Scraper. Three ripper shanks are missing tips, and have been quite worn. It looks like I have to pull a long rod that secures all the ripper shanks, but if I do that is it going to be a bear to get the rod back in? I was wondering if anyone might have a parts diagram and/or owner's manual for this BB, as I really don't know much about it. The nameplate shows it made by Southeastern Manufacturing Co., which I understand was bought by Modern Equipment/Dragon Products. I did a fairly extensive internet search but could not find documentation for this scraper. Thanks.
/ BIg Ox Rollover Box Scraper #2
Pull the rod, it isn't that hard to get it back in. I have a couple of these except mine are Gannon's.
Thanks Brian. I will give it a shot this weekend (leave and get home in the dark this time of year!)
Bob
/ BIg Ox Rollover Box Scraper #4
Bob
As long as you have the rippers pointed up, or so that their notches are up, it's not that hard to get the rod back through.
I have a Gannon Earthcavator RO-Box Blade and we pulled all ours out to put on rust inhibitor and repaint the ripper shafts/bars.
They went back pretty easily even with the new layers of paint.
The notches kinda guide it through.
Thanks! I had fears of pulling that rod and ending up with a situation that only an octopus could handle!
Do either of you know if the ripper shanks for your Gannon are the same as for the Big Ox? Three are missing tips, and they are worn a lot, so they should be replaced.
Bob
BTW, I grew up just north of Rome, NY, so that would be "see the BIG lake-look just right of it!"
/ BIg Ox Rollover Box Scraper #7
Bob
Bob, I don't know for a fact, but I think that they would be, being the same design and all. I don't think that you want to get Gannon rippers tough, or maybe I should say that I doubt that you want to pay for Gannon ripper shanks. I believe that they are $60 each + you still have to purchase the teeth to go on them. They ARE NOT CHEAP. I think that you can get some aftermarket ones for around $30 each and they come with the teeth already crimped on them.
Good luck with that search. ;)
/ BIg Ox Rollover Box Scraper #8
I'd say that the gannon shanks are worth the extra $$. A buddy has a lower end box with the lower end ripper shanks. His bend. The Gannon ones in mine don't. It's worth it to me.
/ BIg Ox Rollover Box Scraper #9
The Gannon ones ARE awesome, but it wouldn't hurt to try the aftermarket brands.
They're not the same as going to a cheaper box blade, where the ripper shanks may not be as well supported.
Try agri-supply, belarus, messners, ebay, and TSC, but ABICR, TSC doesn't carry notched shanks, so that mayn't be helpful.
Best of luck,
Thomas
/ BIg Ox Rollover Box Scraper #10
Oh, most definitely. Very nice.
Thanks to all of you for the suggestions and perspectives. It is very helpful. Here in NE Nevada we are a tad light on options (wish we had TSC for sure), but the internet is our friend!
Bob
/ BIg Ox Rollover Box Scraper #12
Bob
Sometime it turns out to be to be both the most cost- and energy-efficient way to shop.
I just wish that all online vendors were better about updating their inventory listings....
/ BIg Ox Rollover Box Scraper #14
Here are some photos of this BB before I did anything to it (such as weld on new cutting tips, which I will do tomorrow, weather permitting).
http://i365.photobucket.com/albums/oo99/Elkotrailrider/DSCF3433.jpg
http://i365.photobucket.com/albums/oo99/Elkotrailrider/DSCF3432.jpg
http://i365.photobucket.com/albums/oo99/Elkotrailrider/DSCF3431.jpg
Hi Dingo,
That's surely some heavy steel!! [My BB's Big Big Big cousin- for e.g., mine only has one set of the flanges supporting the scarifier bar front and back.]
Cool that you already have a 2" hitch on there- I ended up bolting mine on a little off-center [the flange is on center, so I had to offset from that and I'm not welding good enough yet to risk my BB].
Where did you end up buying your tips?
Unless they're different from the ones already on there, they're not really welded on, more like heated and crimped at the circular area on the shank [and tip] using a hammer and punch [like a really big nailset, IIRC].
Thomas
Hey Thomas:
Yes, this bad boy is stout, with the side plates being 1/2" thick! I bought my tips at the local Kubota dealer, who had several styles in stock.
Thanks for the tip about the crimping thing. I chose to weld these on because two of the shanks were badly worn. When the tips are worn on those shanks, it will be time to replace the shanks, and then all tips will be crimped as you suggested.
Once I got the tips on today, I found out why the grease fittings wouldn't take grease: the axle is totally rusted to the outside bearing retainer. I shot a can of WD40 on it, pounded like crazy (got about 90 degrees of motion on one, about 30 on the other. If I remove the two bolts on each retainer, I can flip the tool to engage the rippers, but this is not an acceptable method. Not entirely sure of how to proceed from here, except to keep putting penetrating oil on the thing and hope it eventually loosens up enough to pull it apart and clean it up (I seriously doubt that I will find replacement parts, so I have to make what I have work).
On the positive side, I just spent two hours cutting sharp edges off of ditch banks in dense silty clay. The Kubota had no trouble pulling this monster, and because of the extendable lower links, hitching up was a breeze! Just have to get the axle freed up, and it will be a wonderful addition to my implement collection.
Bob
BTW, what I am calling the bearing retainers is the black rectangle with one rounded end next to the Big Ox label in the second photo.
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
2016 CHEVROLET CAPRICE CAR (A66091)
2016 CHEVROLET...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
2005 Sterling Cab (A66736)
2005 Sterling Cab...
2026 323W Stand-On Mini Wheel Loader Skid Steer (A66734)
2026 323W Stand-On...
2019 Kubota RTV X900 4x4 Diesel Utility Cart (A66734)
2019 Kubota RTV...
