Big enough AND small enough
   / Big enough AND small enough #1
Highsmith
Kingsbury, TX
Kubota L2350DT, BCS 853
   / Big enough AND small enough #2
I think that would work - or a JD 5525, which is roughly the same size. Maybe a JD 5603 to get a cab and 99 PTO hp with about the same physical size?
Not sure how many post holes you're planning to dig, but if it's into the 100's or 1000's I would be thinking of a skidsteer or power-trac for speed and precision.
   / Big enough AND small enough #3
If you have a lot of posts to do think about a post driver instead . quicker and better. If you are going to use it for planting that's a different story.
   / Big enough AND small enough #4
You could always get a QA and a hydralic QA mounted post hole digger. I think it is a little easier to use when up front and you get down pressure.
   / Big enough AND small enough #5
I am not sure internal hydraulic pumps have enough flow for the hydraulic motors on Skid steer attachments. Maybe the bigger ones.
   / Big enough AND small enough #6
Skid Steer Attachments - Quick Attach Attachments, Inc.
Two models available 10 gal/min to 25 gal/min and 15 gal/min to 30 gal/min
if he is looking at 90+ hp it should be able to handle it.
JD 5525 -- 25.3 GPM
JD 5603 -- 22.5 GPM
TT75A -- 19.3 GPM
   / Big enough AND small enough #8
If you do go for a high hp utility.. make sure you have the weight to handle the hog.
Good luck.
Soundguy
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
J and L Cargo Express Shadowmaster Enclosed Trailer (A53472)
J and L Cargo...
UNUSED FUTURE XJ3T 3TON 30" HYD THUMB CLAMP (A51248)
UNUSED FUTURE XJ3T...
