beveling plate
/ beveling plate #1
deereman75
canada
Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
I am wondering how all of you bevel the edges of plate before welding. I use a 7 inch angle grinder, but there has to be a better way.
/ beveling plate #2
Depends on your budget, level of experience, thickness of plate and how elaborate you want to get.
A small amount I'll use a grinder, heaver plate say for a loader cutting edge I'll use a radiograph Products , a small amount a hand torch and a grinder to dress it up...Mike
/ beveling plate #3
Yup, a tractor torch is the only way to go. I paid $50.00 for this one. :thumbsup:
/ beveling plate
wow another good deal....
Since I do not have the space for a tractor torch, how hard would it be to free hand it with a cutting torch, and clean it up with a grinder. This is mainly for fairly small pieces, I am wanting to try multi pass welds on scrap plate when I get the powerarc 200, and I will probaly using up to half inch thick, and 6 inch wide, for that should I free hand it with the torch and clean it up with a 5 inch grinder, or get out the 7 inch and just grind it all.
/ beveling plate #5
Just put a straight edge on the plate, and tilt the plasma torch to ride the edge at a 45 degree angle.
/ beveling plate #6
I have one similar to yours, but no track. Do you think it would ride two small angle iron strips?
/ beveling plate #7
You can free hand that, or build yourself a burning bar. You don't need a magnetic one, just use a pair of vice grips. Maybe take two pieces of 1 1/2-inch flatbar 18-inches long, tack them together on edge at say 35-degrees, tack another piece in the center 90-degrees from the two others, this is where the vice grips will clamp.
Here is a magnetic burning square I've had for years.
/ beveling plate
Ok so free handing will work. I think I will try to build a burning bar like you sugested. Just have to get the oxygen tank filled first.....
/ beveling plate #9
I don't see why not, just use flatbar to maintain the width.
I worked where someone took a piece of 6-inch round stock inserted a concrete nail in the center of the round stock, drilled a 1/2-inch hole through the round stock, inserted a piece of 1/2-inch round stock, as a shop built protractor, and cut large diameter circles with a tractor torch by turning the wheels. Worked great.
/ beveling plate #10
We used a track torch like that to cut our beveled plates for the plate tests we were doing in class. We'd clean them up on a large belt sander/grinder with a flat section. The track torch had a front pair of wheels with a groove in them that rode on a piece of angle as the guide track. The back wheels rode on the flat platform, unguided.
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
2025 Miva VA15 (A60463)
2025 Miva VA15...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Woods DS8.50 (A60462)
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
