Better battery access.
/ Better battery access. #1
Marveltone
Somewhere north of Roseau, MN
Fordson Major Diesel, McCormick Deering W4, Ford 1510, John Deere L111
Okay, I'm sick and tired of having to remove the FEL brace to open the hood to reach in front of the radiator to put clamps on the battery to either charge the battery or jump-start the tractor.
Solution? I purchased heavy duty quick connects, inserted a pair in my jumper cables (about 1/4 to 2/3 from one end, giving me long and short cables to work with) and using a section scavenged from my jumper cables, made a charge/jump point on the side of the tractor with a matching plug to mate with the jumper cables.
I can now charge or jump the tractor without having to touch the hood.
Joe
/ Better battery access. #2
They sure are great. I did the same thing a few years ago with my old forklift. Good stuff. :thumbsup:
/ Better battery access. #4
I've got a set as well, sticking out from the grill of my JD4300, (also a set on my pickup) Booster cables will plug into either one...or if needed I can hook the battery charger clips to them
/ Better battery access. #5
How many amps will those connectors handle ?
E/S
/ Better battery access. #7
It 50 amps enough to jump start a tractor ?
E/S
/ Better battery access. #8
Depends on the size you buy. Some of mine are good for #2 wire (over 100amp continuous rating), others came with connectors for #10 wire (smaller size plugs). Many sets of booster cables are made of #6 wire which is normally rated for about 50-60 amps continuous use. I believe the large connectors say 400amps on them....but that would be for booster cable type use(intermittent), not lift trucks (continuous)....
I use a set on my 8000lb winch and have never had a heating problem...much the same load as a starter but for longer periods
/ Better battery access. #9
Interesting.
Thanks
E/S
/ Better battery access. #11
They will handle 50 AMPS.
Those are at least the 175 amp if not 350 amp Anderson SB series connectors. The shells may be populated with contacts made for different wire sizes. The connectors are genderless and are easy to work with. These are the connectors that warn uses for their portable winches. Have them on all the power supplies, batteries and equipment in my ham station.
Anderson Powerpole & SB Multipole Series Sets: Bags of housings and contacts in different sizes
David Kb7uns
/ Better battery access. #12
Yes, I checked some of my large Anderson connectors, 175amps and 600 volts (?) Think I'll stick with 12 volts.....
