Better battery access.
/ Better battery access. #1
Marveltone
Somewhere north of Roseau, MN
Fordson Major Diesel, McCormick Deering W4, Ford 1510, John Deere L111
Okay, I'm sick and tired of having to remove the FEL brace to open the hood to reach in front of the radiator to put clamps on the battery to either charge the battery or jump-start the tractor.
Solution? I purchased heavy duty quick connects, inserted a pair in my jumper cables (about 1/4 to 2/3 from one end, giving me long and short cables to work with) and using a section scavenged from my jumper cables, made a charge/jump point on the side of the tractor with a matching plug to mate with the jumper cables.
I can now charge or jump the tractor without having to touch the hood.
Joe
/ Better battery access. #2
They sure are great. I did the same thing a few years ago with my old forklift. Good stuff. :thumbsup:
/ Better battery access. #4
I've got a set as well, sticking out from the grill of my JD4300, (also a set on my pickup) Booster cables will plug into either one...or if needed I can hook the battery charger clips to them
/ Better battery access. #5
How many amps will those connectors handle ?
E/S
/ Better battery access. #7
It 50 amps enough to jump start a tractor ?
E/S
/ Better battery access. #8
Depends on the size you buy. Some of mine are good for #2 wire (over 100amp continuous rating), others came with connectors for #10 wire (smaller size plugs). Many sets of booster cables are made of #6 wire which is normally rated for about 50-60 amps continuous use. I believe the large connectors say 400amps on them....but that would be for booster cable type use(intermittent), not lift trucks (continuous)....
I use a set on my 8000lb winch and have never had a heating problem...much the same load as a starter but for longer periods
/ Better battery access. #9
Interesting.
Thanks
E/S
2016 Homemade 7'X20' Trailer w/Ramps (A60462)
2016 Homemade...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
John Deere 5103 (A53317)
John Deere 5103...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2017 Peterbilt 579 (A60462)
2017 Peterbilt 579...
2016 PETERBILT 365 (A60736)
2016 PETERBILT 365...
