Best Tractor?
/ Best Tractor? #21
I think I'd have to agree about using a riding lawn mower if only mowing one acre.
As to the size of the tractor, Here's my experience on the two tractors I've owned, one of which is a dx24, previous years model from one of the tractors your considering.
Case DX24 - 60" mid mower, loader, & post hole auger.
When purchasing my first tractor 2 years ago - One of my main concerns was having a tractor small enough to get into tight places in the yard and light enough to mow without damage. I put 240 very hard hours on the tractor doing loader work, clearing, mowing, drilling, etc. The tractor was an excellent machine and I could not have expected more for its size. I had no mechanical problems at all. It didn't take me long though to figure out that I was asking my tractor to do more than it was intended to do. It also needed more pushing power and lift from the loader for the type of work I was doing. Small bites at a time were key for the loader in packed dirt and lifting a full heaping bucket of damp dirt was difficult. I soon found myself wanting a bigger tractor. I planned to upgrade to a dx29 until the dealer talked me into a dx33. I could not have been happier and owe my dealer big time.
Case DX33 - 72" mid mower, lx114 loader, quick attach bucket & pallet forks, post hole auger
This tractor makes by dx24 feel like a toy. I could not believe the difference in power. This is the tractor I should have bought in the first place. Plenty of power for loader work, plenty of lift for the loader as well as pallet forks. The 72" mower deck makes mowing my 4 acres a snap. It's still not overwhelming in size (although it did feel huge going from the 24) and I can get into all of the tight places that I was able to get to with my dx24. (sometimes not quite as easy though). I've put 84 hours on the tractor so far and couldn't be happier.
Final thoughts. When I bought the dx24 I was considering this or a Kubota BX23. I went with the dx24 due to the larger size and thought I was buying more than I needed. I soon found way more uses for the tractor than I imagined and ended up back at my dealer to upgrade to the 33. Happy hunting.
jk
/ Best Tractor? #22
One other note I forgot to mention. I have a 300 foot gravel drive and 150' x 200' gravel parking lot that I have to remove snow on using a rear blade. The dx24 often lost power in 2nd gear (hydro) with a heavy snow. First gear was just too slow for this size of area. Also, when using the rear blade to grade dirt, the tractor had plenty of power in first gear but would loose traction and pull sideways when the blade got full, even with the front loader attached for weight and using 4wd. My DX33 has plenty of weight and power for dirt work with the rear blade, can't wait for it to snow to tackle the parking lot.
jk
/ Best Tractor? #23
I just do not like the subcompact tractor as a concept. I know many posters buy them and have great luck and there are many quality sub-comp's out there. Honestly, I could probably get by with one myself, rather than what I have. I will cite the brand with which I have the most familiarity as an example: John Deere. When I was looking to trade my very nice and really handy X595 for a subcompact, I started to see that the price of the machine at the time (2210) was close to that of a 4110, which had a full Cat 1 hitch and was a heavier machine with better hydraulics. I eventually went to a mid frame, then to a large frame and then back to a mid frame (3720) which I have now. I love the machine. It truly is almost as compact in footprint as a 595 (seriously) and is five times the machine as the 2210 or 2305. It is, of course, a lot more expensive as well, which I had to weigh at the time of purchase. That said, I have no regrets. I use my tractor to finish mow at my parents and their lawn looks as good or better when I am done as it did when I mowed with the 595. The tractor does not tear up grass and will only leave a slight imprint on the turf even when wet. It will also shoot a brick (which was in the grass) about 150' out of the RFM chute, which I found scary but impressive. Realizing that our poster might be interested in looking at a smaller machine that can mow well and do other things, I would say a small frame compact--no matter which brand--would give him the best for his dollar. On average these machines are about 200-400 pounds heavier than a subcompact, come with the benefits (plus others) listed above and will carry better resale on average due to their ability to take full Cat 1 attachments, which the JD subcompact would not, and I assume some others would not either. These benefits come at an additional cost of about $2K-$3K in most cases, money which is absorbed over the lifetime of the tractor.
John M
/ Best Tractor?
Well thanks for the advice guys. It all seems more overwhelming to me now. :D
Sound like my dream of a do-it-all machine was in fact, only a dream. Part of my buying justification was that I would not have to buy several other machines (mower, snow thrower, etc) and maintain all those motors with shorter life spans, etc.
Since I have little experience, and have only been a home/land owner for 1.5 months, maybe I will try a different approach. I will try to post a picture of my patch of dirt and see if anyone would suggest what they would use to maintain this property on a modest budget.
Lets see if If I can make this picture work.
/ Best Tractor? #25
Don't let me scare you away from the DX25. My DX24 was everything I expected it to be and more. If your only using it for the tasks you mentioned
Usage:
Mowing 1 acre
Snow removal: 350’ drive
Build-maintain some trails
Light landscaping, garden, maybe some fencing.
This machine will perform perfectly. My comments were only to let you know my experience, which was finding out once I got the tractor I found many more uses for it and realized the abuse I was putting my dx24 through would eventually lead to a shortened life. I think by adding a tooth bar, the digging ability of the FEL would be improved. Also, if your only maintaining a drive way for snow removal, and not a 30,000 sq/ft parking lot like I was it will do the job wonderfully.
jk
/ Best Tractor? #26
What is your budget for the tractor?
Then look for the best bang for the buck~! :D
/ Best Tractor? #27
jk96 said:
I I went with the dx24 due to the larger size and thought I was buying more than I needed. I soon found way more uses for the tractor than I imagined and ended up back at my dealer to upgrade to the 33. Happy hunting.
jk
I have no regrets getting a TN70A (used) versus a TC40DA new. I never go on the lawn (I have riding lawn mower) and I rarely do lot's of close in work that would benefit from HST and smaller frame. At times I wish I had a bigger tractor. But I will always want a bigger tractor :D
Bob
/ Best Tractor? #28
Mr. S,
I'd go with a compact as apposed to a Sub. It looks like most of your property is wooded with trails. If in the future you are considering clearing more of it then definately go a little bigger, I don't think you'll regret it. I also agree with the others a Z or conventional mower for the yard. It really depends on the future plans you have for your property i.e. a pond, more trails, more cleared areas or pastures. All these are things only you know.
Your place looks wonderful, i'm jealous :D
Good luck in your journey.
TomK
/ Best Tractor?
I had in mind $15k maximum. My truck is paid off so I have about $350 in the budget for now. This will change once I need a new vehicle which will be about 4 years as a guess.
I also figure I can get just what I need for now, and just add the "extras" when I have the need/money.
BTW, I love the best bang for the buck!!
/ Best Tractor? #30
For 15k you could get into a new B7510 w/fel for a little more you could jump up to the 7800 and up again to the 3030. Having owned a 75 & 3030, they are both fine machines and offer way more potential than any scut, JMHO, good luck & welcome to tbn.
2008 Ford E-250 Cargo Van (A59230)
2008 Ford E-250...
2011 Dodge Ram 3500 Crew Cab Pickup Truck (A59230)
2011 Dodge Ram...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
Zero Turn Mower (A59231)
Zero Turn Mower...
2011 Ford F750 Bucket Truck (A60352)
2011 Ford F750...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
