best tractor
/ best tractor #1
demodawg
I had narrowed my choices down to a 4120 or 3320 and then someone mentioned to me today to look at the 5103. I was wondering which of these 3 you think is best. I won't spend a lot of time on it, probably 8-10 hours a week. It is also going to be used to move dirt for a motocross track and basic land clearing/maintance/mowing. Thanks,
/ best tractor #2
My neighbor has a 5105 which i think is the same only it has 4wd. It has a shuttle shift trans. It seems too clumsy for mowing other than in open areas and loader work is slower than with a unit with a hydro trans. IMO
/ best tractor #3
I would go 4120.
D.
/ best tractor
OK, so no go on the 5103, thanks. is there much difference between the 4105 and 4120? I am doing all my research before i make my purchase.
/ best tractor #5
I think that there are lift capacity differences, and also hydro transmission differences between the 4105, and the 4120, but I could be wrong.
/ best tractor #7
The 4105 is a two speed hydro.
/ best tractor #9
If you are going to be doing loader work 4WD is definately the way to go. Any model tractor will get the job done, but the bigger it is the more work you can get done in a given time. So get the biggest one you can afford and you will have more time to ride that track.
VERMEER V430 TRENCHER (INOPERABLE) (A67714)
VERMEER V430...
2013 Caterpillar 420F Loader Backhoe (A68183)
2013 Caterpillar...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2014 DIAMOND C 45HDT CAR HAULER (A67714)
2014 DIAMOND C...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
2019 VOLVO DUMP TRUCK (A67714)
2019 VOLVO DUMP...
