Mowing Best RPM for John Deere 1026R while mowing
/ Best RPM for John Deere 1026R while mowing #1
Hojo777
De Pere, WI
John Deere 1026R
I am a tractor newbie. I have a nice new JD 1026R with the 60 inch autoconnect mid-mount mower. I mow about 4 acres of not so lush grass. What is the best RPM to operate the tractor while mowing? I've gotten 3 answers from the dealer (I think I bought the only 1026R that they've sold). I've been told: "Just high enough that is doesn't bog down", "2500 RPM", and "3000 RPM". Thanks in advance for your help!
/ Best RPM for John Deere 1026R while mowing #2
Your owners manual should tell you what RPM you need or should run to turn your mid PTO at it's rated speed, usually 2000 RPM, but some are designed to turn faster - 2,500 RPM, for example. Usually the engine RPM needs to be near max to produce the rated PTO speed, which is what is recommended for mowing. My BX needs to run around 3100-3200 RPM to make its rated mid PTO speed, though I usually mow at 3000 RPM.
/ Best RPM for John Deere 1026R while mowing #3
It's in the manual, basically full RPMs. It's also indicated with a line and symbol on the tach. That RPM gives you the designed for blade speed.
Midwestern Industries MEV Screen Model MEV 5X10-2 (A61306)
Midwestern...
2008 Freightliner B2 School Bus (A59230)
2008 Freightliner...
2020 DRAGON ESP...
2020 KOMATSU HM400-5 OFF ROAD DUMP TRUCK (A60429)
2020 KOMATSU...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
