John Deere 997 engine rpm when mowing
/ John Deere 997 engine rpm when mowing #1
wjpeekjr
Alpharetta, Ga
John Deere 5400
What is the best engine rpm to use when mowing with a John Deere 997 with 72” deck
/ John Deere 997 engine rpm when mowing #2
For any mower in general, I’d run it at the max rpm. That should give you the best cut.
/ John Deere 997 engine rpm when mowing #4
A tractor normally has indicator of engine RPM to get the designed PTO RPMs for the implement. Most mowers if rear mowers on smaller tractors run at 540 pto RPMS. If Belly mower I have no idea the rpms needed for that.
