Best Product for Anchoring New Hoses?
   / Best Product for Anchoring New Hoses? #1
Suburban Plowboy
FL
Kubota L3710
Now that I'm installing rear remotes on my Kubota L3710, I have new hoses flopping around.
Before I spend all day Googling and hoping I come up with a good way to anchor them, is there some product out there that is generally considered best?
It looks like two hoses will have to run inside my rear fender, so I will definitely want to hold them away from the tire and brush.
Thanks. Any particular company?
   / Best Product for Anchoring New Hoses? #4
That looks great. Thanks. And thanks for recommending Surplus Center. Might save a couple of dollars.
Yeah, but how do you buy just the thing you need there? It's like Costco. Hard to leave without buying junk you didn't know you wanted. It's the hydraulic candy store.
Amazon charges over twice as much for that clamp, I believe. Haven't checked shipping, though.
   / Best Product for Anchoring New Hoses? #8
They usually require welding of the threaded base plate to the machine.
I don't see why you couldn't use a longer bolt than the one supplied and drill and nut into lighter metal such as the fenders you mentioned. Ideally you'd find a more inboard location.
Both rubber and wooden sticks are non magnetic, but those 2 sure attract each other!😉
Thanks for warning me. It thought it had a rubber base with a screw that went all the way through.
I don't think I want to try to weld thin sheet metal with my head between the fender and the manure-caked tire. Apart from the fun of trying to get in there, I would have to sand off a bunch of paint and redo it.
There isn't a ton of room between the fender and the tractor.
Welding seems like overkill for a clamp.
Interesting fact: the hoses on my loader just flop around loose. They have worn the paint off a few spots. I should figure out how to fasten them down. I'm pretty sure it's not a good idea to weld things to a cylinder's side.
   / Best Product for Anchoring New Hoses? #11
I keep offcuts of 3/4 and 1-inch UHMW around to make things like theses clamps. Drill and chamfer the holes and then cut them in half. On many tractors, you can switch to longer bolts and install the new clamp over the top of existing ones on teh tractor. That is the TYM, factory method of securing third function hoses on their loaders.
   / Best Product for Anchoring New Hoses? #12
What would be really nice is bulkhead fittings in a bracket that's bolted to the tractor. Then the couplers are supported which makes it easier to connect/disconnect.
I may be able to jam these things in between the tractor and the fender.
   / Best Product for Anchoring New Hoses? #14
Just did remotes on my MF 1734E. Kit came with zip ties and the hoses came with anti abrasion wrap on them. The routing is under the seat away from the fenders.
   / Best Product for Anchoring New Hoses? #15
I used the Surplus Center hose clamps for connecting my hydraulic lines from the grapple to my tractor. I did this 9 years ago and everything seems to be staying put. I added some details about sizing the clamps. Also I do not have an actuator on the loader joystick for the grapple. I use the remote lever to open and close the grapple. I have gotten used to that arrangement. I remember that the 2 lines alone were $300 and with the clamps and qd's I had approx. $400 in this modification. Attached details. I also add the original pictures for more clarity but without the verbiage.
   / Best Product for Anchoring New Hoses? #17
This also makes them easier to break or rip the hose.
   / Best Product for Anchoring New Hoses? #18
Then your hoses must be too short. My three-sets of couplers are mounted on brackets, and I've never had a problem. Soon to be a fourth.
   / Best Product for Anchoring New Hoses? #19
I've done the same with "Trex" type plastic deck boards.👍
   / Best Product for Anchoring New Hoses? #20
I use these insulated cable clamps:
They allow some movement as hose pressure varies, which prevents chaffing. They're made of stainless steel so they won't corrode. I use two side by side and share the same mounting hole for dual hose runs.
(2) 300 GALLON POLY TOTES W/CAGES (A60432)
(2) 300 GALLON...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
GRAIN BIN (A60430)
GRAIN BIN (A60430)
New Holland 3930 (A60462)
New Holland 3930...
2021 JOHN DEERE 50G EXCAVATOR (A60429)
2021 JOHN DEERE...
UNUSED FUTURE CLG72-72" HYD CURVED LOG GRABBER (A60432)
UNUSED FUTURE...
