Best Product for Anchoring New Hoses?
   / Best Product for Anchoring New Hoses? #1
Suburban Plowboy
Platinum Member
FL
Kubota L3710
Now that I'm installing rear remotes on my Kubota L3710, I have new hoses flopping around.
Before I spend all day Googling and hoping I come up with a good way to anchor them, is there some product out there that is generally considered best?
It looks like two hoses will have to run inside my rear fender, so I will definitely want to hold them away from the tire and brush.
Thanks. Any particular company?
   / Best Product for Anchoring New Hoses? #4
That looks great. Thanks. And thanks for recommending Surplus Center. Might save a couple of dollars.
Yeah, but how do you buy just the thing you need there? It's like Costco. Hard to leave without buying junk you didn't know you wanted. It's the hydraulic candy store.
Amazon charges over twice as much for that clamp, I believe. Haven't checked shipping, though.
   / Best Product for Anchoring New Hoses? #8
They usually require welding of the threaded base plate to the machine.
I don't see why you couldn't use a longer bolt than the one supplied and drill and nut into lighter metal such as the fenders you mentioned. Ideally you'd find a more inboard location.
Both rubber and wooden sticks are non magnetic, but those 2 sure attract each other!😉
Thanks for warning me. It thought it had a rubber base with a screw that went all the way through.
I don't think I want to try to weld thin sheet metal with my head between the fender and the manure-caked tire. Apart from the fun of trying to get in there, I would have to sand off a bunch of paint and redo it.
There isn't a ton of room between the fender and the tractor.
Welding seems like overkill for a clamp.
Interesting fact: the hoses on my loader just flop around loose. They have worn the paint off a few spots. I should figure out how to fasten them down. I'm pretty sure it's not a good idea to weld things to a cylinder's side.
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
1980 PULLMAN DRYVAN (A50854)
1980 PULLMAN...
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
