Backhoe Best option for digging 6+ft with PT425
/ Best option for digging 6+ft with PT425 #1
PTWannaHave
Richmond, ON, Canada
1997 Cub Cadet 2185; 2015 PT-1430
Hello all,
Thought my question would best be asked in a new thread rather than continuing with my previous thread about potential owner questions...
I've read quite a bit of material about minihoe & backhoe for PTs, but am still left with the following question:
Like KenT, I live in the North and would like to dig 6+ft to get past the frost line. Unlike KenT though, I do not plan on owning a PT larger than the 425.
The minihoe won't do, a Lackender skid-steer hoe is too large/heavy/demanding for a 425, and I seem to recall that the fella who custom-fitted the backhoe of a PT2425 on his 425 had some stability challenges...
So, does anyone think they have come up with the best off-the-shelf solution to digging 6+ft with a PT425?! (I say 'off-the-shelf' as fabricating a hoe is not an option for me, for several reasons.)
Worst-case scenario, I suppose a beefier and longer version of the minihoe could be built.
Pls. feel free to refer me to earlier threads that I may not have been able to find in researching an anwer to this question.
Thank-you in advance,
PTWannaHave
/ Best option for digging 6+ft with PT425 #2
Depending on what and where exactily you are digging, one idea is to dig a "ramp" down deeper then drive down the ramp and dig, in order to get the hole deeper.
No denying it's more digging, but if it's not very often you need the extra depth, it would solve your problem.
I've only done it once and it was less than a foot-deep "ramp" because it gave me the extra depth on the hole I needed. You can see my "ramp" in the second post, the middle attachment here:
http://www.tractorbynet.com/forums/power-trac/96728-rock-b-gone.html
I seem to remember Catsco in Colorado did something similar but longer and deeper, but I didn't see a thread title under his posts that immediately indicated which one it was... but maybe I'm confusing him with another member.
Phil
/ Best option for digging 6+ft with PT425 #3
Other than a longer dipper arm for the mini-hoe, I see no other solution than a backhoe attachment for a 1425 adapted for the 425.
Or, you could just plan your projects and rent a small excavator. They are relatively cheap to rent, dig faster than a backhoe and are built for the job. I have rented one and it worked really, really well. :thumbsup:
/ Best option for digging 6+ft with PT425 #4
I have a lighter duty Lackender mini hoe but my guess is that it is still too heavy. I think they call it the baby boomer. Digs 6' deep but no swing.
Ken
/ Best option for digging 6+ft with PT425 #5
Ptwannahave I dug out a hole for a septic tank a long time ago with my 425. I used the rock bucket and naturally the hole was wider than the bucket. I dug a ramp down into the hole as I dug it and I dug it deep enough as well as I remember till the ground level was over the top of the rops. After I dug it deep enough for the tank I put the minihoe on and dug the ramp out as I backed up the ramp [scary], and when I was done I had enough room at the end of the tank to put an overflow tank in.
/ Best option for digging 6+ft with PT425 #6
On my minihoe I built a thumb for it and it improved the use of the minihoe a 100% for picking up rocks and such. I also use the minihoe with the thumb as a grapple to pick up brush to carry to the burn pile. I also carried a log with the minihoe with the thumb to get it out of the yard, had to keep the log close to the pt as I could to keep from biting a hole in my seat.
Thanks all for the responses!
I am thinking about the equipment necessary to dig a trench for a poured foundation...
If I buy a PT, I may just have to contract out that kind of work (which I would not have to do with a CUT).
Bye for now,
PTWannaHave
/ Best option for digging 6+ft with PT425 #8
Bye for now,
PTWannaHave
That's not quite fair. There are several PT's capable of digging this stuff, but not the PT425.
There are two PT2445's on the used tractor list, that are more than capable of digging to China......... and they are priced lower than most CUT's that you could find.
Used Power Tracs
As for the 425, that one ad is really nice, man they got all the attachments. I like the homemade boom saw. I am looking for a 1460, and it is really hard to find a used one, but lots of nice 425's.
Thanks for the link 3238dpw!
Your point is well taken American Bulldog... Perhaps stacking up a PT425 vs. a 23-27hp CUT (with a WOODS backhoe) is unfair.
I will keep mulling this over...!
Regards,
/ Best option for digging 6+ft with PT425 #11
Can I offer two cents?
You might want to figure out how much pipe you intend to lay and price getting it done by someone else, vs renting a 8' trencher vs trying to get it done with a PT. If you think you are going to do a lot of trenching, there is always the 2425.
If you went the route of getting a longer trencher welded up, it won't be cheap, but it might be the cheapest of the the options. Bear in mind that the 425 only has about 13HP of PTO power, so trenching 6' down may not be terribly quick.
All the best,
Peter
I think this skidsteer minihoe would be a good alternative to the PT one: eTerra E60 Backhoe. (Similar to Lackender one I assume.)
I am quite impressed with the product offering by SSS... If PT does not make what you want, check SSS. You might find what you need in either the Skidsteer or Mini-skidsteer sections. (Think rock (skeleton) bucket.)
In some cases, the SSS price is better, and quality should be the same? (Think adjustable forks for the PT1430...)
At less than 500lbs, the E60 minihoe could probably be used by a PT425...
Cheers,
/ Best option for digging 6+ft with PT425 #13
Since the 425 only has 800 lbs of lift, theoretically at the QA plate, you wouldn't have a lot of power/capacity left to lift things in the bucket. Remember that the farther away you get from the QA plate, the less you can lift due to the leverage -- the front wheels are the fulcrum for this weird, articulated lever...
In comparison, I'm not sure what the PT minihoe weighs, but I'd guess its 100 lbs max.
Good point about the weight/balance on a PT425, Kent. I don't know if there would be a way of figuring out the actual effectiveness of an E60 minihoe on a PT425, without actually trying/testing it...
It's one of the reasons I'm leaning towards a PT1430, as digging 4-6ft deep is fairly high on my "jobs that I currently contract out" list. A PT1430 should be able to handle the E60 minihoe with relative ease...
Merry Christmas to all,
/ Best option for digging 6+ft with PT425 #15
So, this is just me...
I am not a fan of my Lackender / PT styled backhoe (which I own the Lackender and it is well constructed and does the job as designed). It is WAY too hard to get a job done, but I know lots of you are very skilled in this use. Maybe it is the 1850 wheel setup, but the process is too heavily blocked by the lift arm to see where you are digging, and the results are always marginal with the digging tailings not getting moved far enough away, and the ground damage from the wheels turning left and right.
I have to say I have really liked the guy who just bought the 2XXX Series backhoe and added it to his lift arms of his 1XXX Series. He can sit on it and operate it like a real backhoe. A PITA if you are doing long trenching and you have to climb on and off, but I think a much quicker way to get the work done and a lot less surrounding ground damage.
/ Best option for digging 6+ft with PT425 #16
I have done quite a bit of trenches (>400') and foundation holes with the Lackender and have been really impressed. I was able to do the work more comfortably than with the ford tractor i had with the 9' deep backhoe. The PT was faster for trenching but the Ford could lift bigger rocks. Once i got the hang of it, the work went fast. Pivoting to dump can damage the ground so i use the treadle to move back and forth while doing that. That made the digging faster and less damaging. I was amazed that i could dig through 5' of layers of shale and clay in a relatively small hole. I thought i was hard on the tractor but it seems to have taken the abuse.
Now the Lackender Boomer Hydraswing would be sweet but it is 650 lbs:
http://www.lackender-fab.com/boomer-hydra-swing.php
Ours are probably 450 lbs, maybe less
Ken
/ Best option for digging 6+ft with PT425 #17
No one should get me wrong on Lackender. It is VERY well made stuff, I am just not patient enough to do 400 feet of trench...
/ Best option for digging 6+ft with PT425 #18
Seriously, I can do 400' of shallow (2' -3' deep) trench faster with the PT than I could with a permanently mounted conventional tractor backhoe. Six feet deep would be faster with the traditional backhoe setup. Now if i had a nice dedicated extend-a-hoe with 20' or more of reach - well, now we are talking! Although backhoes are pretty hard on a lawn. A trencher does the least damage.
Ken
/ Best option for digging 6+ft with PT425 #19
Hello all,
PTWannaHave
Perhaps something like this. Use the backhoe of the chain trencher
/ Best option for digging 6+ft with PT425 #20
Hey, Santa's back on TBN! Nice to see him again! :thumbsup:
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
UNUSED KJ K0720-7'X20' METAL FARM DRIVEWAY GATE (A60432)
UNUSED KJ...
2023 CATERPILLAR 259D3 SKID STEER (A60429)
2023 CATERPILLAR...
John Deere 5090GN (A60462)
John Deere 5090GN...
2018 VOLVO EC480EL EXCAVATOR (A60429)
2018 VOLVO EC480EL...
