Best implement for road grading, for a 40HP CUT, regardless of cost?
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #1
beppington
Elite Member
of my
Here
... for a limerock road in N Central Florida. This road tends to get little depressions, from where tires hit water & spray the water out off the road, & is "wavy" from where the limerock delivery man didn't spread the limerock as he drove, he just dumped it in small piles, & it was never graded out smoothly. Currently I think the guy that grades the road just lets his box blade float along the road, which slightly improves it each time, but leaves a lot to be desired.
Best I can determine it would be a rear grading blade with hydraulic tilt, offset & angle functions, with a hydraulic gauge wheel, such as Land Pride's RBT3584 (7') or RBT3596 (8').
What do you think?
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #2
Start with new material...say maybe 3/4 gravel or stone. Then, the implement is cheap.....$700 Box Blade.:thumbsup:
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #4
See Land Pride Grading Scraper for an example. There are many brands out there. I own a Land Pride, but I'm sure they are all similar and works well. The Grading Scraper is similar to a Box Scraper but has a few features meant specifically for grading a road.
Land Pride Grading Scrapers
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #5
[QUOTEBest implement for road grading, for a 40HP CUT, regardless of cost? ][/quote]
Cost no object then lets start looking at Cat graders with a ripper bar and dozer blade.:thumbsup:
images
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #6
To do what is needed, you will need something that will angle (note the feature in the road grader pic by Egon).
Carry that idea back to whatever tool is used and a rear blade with height adjusting wheels which angles is the best tool sans a road grader. The box blade with rippers would be great if there was one that would also adjust to an angle.
And I see the Road Boss posted by Compact1 has an angled blade (clicked on the link, and had to turn the sound off....why do these people put sound on a video? :mur: :p )
Come on now, I said implement for a 40HP CUT!
images
See how this grader has wheels both in front of & behind the grading blade - That's my reason for including the gauge wheel ... to make the machine as loooong as possible, for smoothness, to reduce those waves I mentioned.
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #9
A two blade scrapper grader would do wonders for your road. I maintain a one acre equipment lot that has crushed concrete as the surface. I used to use a box blade. The scapper works much better for maintaining the lot.
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #10
I know. :D
But look at the response with comments about the grader blade and angle. The blade also tilts which makes cutting easier or laying out the windrow easier.:thumbsup:
So; look for an implement the emulates those characteristics. They are out there and are frequently used in irrigation areas. They are not cheap. :)
2019 TAEKUCHI TL8 SKID STEER (A51242)
2019 TAEKUCHI TL8...
2010 POLARIS RANGER 4X4 4 SEATER UTV (A51222)
2010 POLARIS...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2012 PETERBILT 388 NATIONAL CRANE TRUCK (A50854)
2012 PETERBILT 388...
