Best implement for road grading, for a 40HP CUT, regardless of cost?
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #1
beppington
Elite Member
of my
Here
... for a limerock road in N Central Florida. This road tends to get little depressions, from where tires hit water & spray the water out off the road, & is "wavy" from where the limerock delivery man didn't spread the limerock as he drove, he just dumped it in small piles, & it was never graded out smoothly. Currently I think the guy that grades the road just lets his box blade float along the road, which slightly improves it each time, but leaves a lot to be desired.
Best I can determine it would be a rear grading blade with hydraulic tilt, offset & angle functions, with a hydraulic gauge wheel, such as Land Pride's RBT3584 (7') or RBT3596 (8').
What do you think?
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #2
Start with new material...say maybe 3/4 gravel or stone. Then, the implement is cheap.....$700 Box Blade.:thumbsup:
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #4
See Land Pride Grading Scraper for an example. There are many brands out there. I own a Land Pride, but I'm sure they are all similar and works well. The Grading Scraper is similar to a Box Scraper but has a few features meant specifically for grading a road.
Land Pride Grading Scrapers
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #5
[QUOTEBest implement for road grading, for a 40HP CUT, regardless of cost? ][/quote]
Cost no object then lets start looking at Cat graders with a ripper bar and dozer blade.:thumbsup:
images
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #6
To do what is needed, you will need something that will angle (note the feature in the road grader pic by Egon).
Carry that idea back to whatever tool is used and a rear blade with height adjusting wheels which angles is the best tool sans a road grader. The box blade with rippers would be great if there was one that would also adjust to an angle.
And I see the Road Boss posted by Compact1 has an angled blade (clicked on the link, and had to turn the sound off....why do these people put sound on a video? :mur: :p )
Come on now, I said implement for a 40HP CUT!
images
See how this grader has wheels both in front of & behind the grading blade - That's my reason for including the gauge wheel ... to make the machine as loooong as possible, for smoothness, to reduce those waves I mentioned.
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #9
A two blade scrapper grader would do wonders for your road. I maintain a one acre equipment lot that has crushed concrete as the surface. I used to use a box blade. The scapper works much better for maintaining the lot.
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #10
I know. :D
But look at the response with comments about the grader blade and angle. The blade also tilts which makes cutting easier or laying out the windrow easier.:thumbsup:
So; look for an implement the emulates those characteristics. They are out there and are frequently used in irrigation areas. They are not cheap. :)
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
McKee 504 3pt. Snowblower (A50774)
McKee 504 3pt...
2002 WACKER RD25 ROLLER (A51222)
2002 WACKER RD25...
Hilti TE 2000-AVR Electric Jack Hammer (A49461)
Hilti TE 2000-AVR...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
