Best and worst chainsaw?
   / Best and worst chainsaw? #261
I have had the same Stihl Farmboss saw for about 30 year. It has had to have a couple trips to the shop for tuneups and minor repairs, mainly to the fuel lines because they tend to break down over time. My expaierience is that it is not so much the saw as the chain you use. I bought a couple of "consumer grade" safe chains that would burn through a log faster than cutting it. A logger friend told me to go to a pro shop and ask for what he called a "skip tooth" chain. He said I would have to be careful or it would tear me up, but it cut through the same logs extremely fast and smoothly. Also, keep your chain sharp. Like a dull knife, a dull chain is much harder to deal with.
Have you ever seen a cutter like this?
   / Best and worst chainsaw? #262
Your photo prompted my question, both to you and any other chainsaw cognoscenti:
Background: I have used chainsaws (fire service roof operations, and ranch/firewood duties). I no longer perform either (residence no longer supports the need), nor possess a chainsaw.
Requirement: I intend to purchase a chainsaw for preparedness purposes. It will, in all probability, never be used. It will function as a "break glass in case of emergency" item for clearing downed trees to enable emergency egress/travel. I intend to store it in a saw case together with an extra bar, 2 additional chains, Stihl pre-mixed fuel, bar oil, etc.
Question: Does storing a never-fueled/never-operated, virtually new-in-box saw create any long-term issues to the saw itself?
(I considered a cordless/battery model, but with zero use for potentially years, battery life would be an issue.)
Thank you in advance for any input.
I'm just wondering what you are going to do with this brand-new saw that's never been run, and a big emergency pops up. You take it out of the box, and it turns out to be one of the late Friday afternoon saws that the guy putting it together has a hot date with a cute little hotty that has called him 5 times during the day reminding him of their date tonight. Sometimes stuff just happens, and you get a dud. In an emergency that's not the time to find out that you have bought one.
Get that sucker out of the box and run that thing at least long enough to get it broke in good. That way you can address the issue before your life depends on it.
I don't mean just take it out of the box and go outside start it up and rev her up a few times. Put the bar in some wood and let her eat for at least several tanks of gas. That's the only way you will know what you have. Three tanks of gas are not enough time to get it all the way broke in but at the very least you will know by then you didn't get that dud. Don't worry about the gas being left in the saw for long periods because these newer saws just like boat engines, 4 wheelers, name brand lawn equipment all have been built with materials that can take the use of the gas we have today. They are designed and built to run on reg ethanol pump gas.
I remember back in the early 80's when Mercury marine engineers finally figured out why all the fuel lines, gaskets, fuel pump rubber parts were turning to mush. They took the gas companies to court and was only one of the very few times Mercury ever lost in court. The ruling was that if they wanted to build engines, they needed to build them to run on what gas was available. It took them a couple years to come up with rubber parts that could handle pump gas, but they did it. I can't say much about the box store saws and other stuff you get from them, but I do know any of the name brand saws and equipment have been built to run on reg pump gas. The ones that saw you have to run their canned fuel for your warranty to stay active are just trying to soak the last bit of change you have in your pocket.
I'm not saying not to run the canned fuel that's your choice, run what you think is best. All I know is what I have found to be true there's nothing wrong with running pump gas. I would recommend you use the oil that the brand of saw has to offer. Water is the biggest problem to worry about with any engine especially 2 stroke engines.
Do yourself a favor and get that saw out and run the heck out of it for several hours and you should get her out every 5/6 months for a spin just to let her know you still love her.
   / Best and worst chainsaw? #263
Pick a brand of battery powered lawn equipment that you want to use (string trimmers, blowers, ect), and get a chainsaw that matches. I know that the power will be out when its time to use it, but keep 3 batteries charged and you won't need to worry about that. 3 batteries is enough to do quite a bit of work so long as you not cutting everything into firewood lengths. Cut it short enough to move it, and that's it.
Sitting there on a shelf, the rubber (intake boots, fuel line, oil line) on a gas powered tool will eventually dry out just like the old brake and vacuum lines on a car that sits in a garage or barn for years. If you use it from time to time, then you can run into carb issues if you use fuel with ethanol in it. Even with non-ethanol fuel, you still have varnish that can build up. Bottom line is that if you use it, it WILL eventually have starting issues. If you don't use it, eventually the rubber will dry out. With battery tools, when you squeeze the trigger, it turns on. Besides, battery powered string trimmers are nice and light :)
Bull****ske..........
   / Best and worst chainsaw? #264
We have several Stihl MS 250’s and they have been very good saws. Aside from our Stihl fleet of chainsaws, we have been buying Echo Chainsaws recently. It’s hard to beat IMHO Echo for the price and feel they make great 2-cycle engines.
We have a 620PW which would be close to the 590.
My recommendation is go with a 50cc saw as a companion to your 590. We have a 501P and like it. I feel the 4910 is a better value and with a few exceptions, pretty much identical to the 501P. You might still find a 4910 at Home Depot or a dealer.
Another saw Echo recently discontinued is the CS400. If you look, you can still find a left over. They are a great saw too. We have one of these too.
Best of luck!
I had an MS250 for over a decade and it was a great saw for its price range for sure, never a lick of trouble from it when used within its duty cycle. It did tend to get hot when used for hours and would vapor lock sometimes but I was using it more than it was designed to be used. I replaced it with the 261 and it was a nice upgrade in both power and comfort but at twice the price of the 250 that was expected.
   / Best and worst chainsaw? #265
Depends on what you are cutting.
I had a Makita 36v 12", and a Makita 36v 14". The 12 was good for limbing and small brush. The 14 was good for anything up to about 10". They were both stolen along with my Stihl 390.
I replaced the Stihl with a Husq 562 mkii, and I absolutely replaced that 14" Makita. The 12 can wait.
   / Best and worst chainsaw? #266
We used to live extremely rural. Intermountain west in a 1500 square mile county with 3000 people. Heavy timber area; we used to drive 10 minutes to harvest 20 cords. Now we have zero ability to run a saw as you suggested. We are now suburban residential, and the saw is intended for the aforementioned usage. I might have to write off the planned acquisition of a saw since it seems that it will not be a piece of equipment that can lie dormant and still be available for use.
   / Best and worst chainsaw? #267
Mine too... he reminiesed of being able to not have to lock your doors or getting sued as a business because the public restroom sink was a half inch too high and the police actually came when called...
We dont lock our doors out here and quite frankly never have, not even when we leave for a couple of days! I hate to admit it, but we don't have a clue where the keys to our house actually are. Don't use them, so they just ended up somewhere quite some time ago! Just one of many reasons we love it out here!
   / Best and worst chainsaw? #268
At 82 my Ryobi 14" 48V chainsaw is perfect, by the time the 6AH battery is run down so am I. I go to the house for R&R, put the battery on the charger, grab the 4AH battery, put it in the saw. Then sit on the back porch and drink a couple glasses of cold beverage for an hour.
If I'm feeling good I go saw until that 4AH battery is run down, then call it a day.
I have 2 great Echo gas saws, but my bad shoulders will not allow me to start either.
   / Best and worst chainsaw? #269
Ok a couple of things I have found over the years on saws:
Sharp chain - whatever style floats your boat. I like Oregon chains and bars.
Since I live in the Peoples Republic of Connecticut and alcohol free is not an option... Use Ethanol Shield to suspend the water. STA-BIL of any color is absolute cr@p!
Put a few drops of water in straight STA-BIL and see what happens - or not, as it just sits there. Put the same in Ethanol Shield and watch the magic happen as it emulsifies the water away.
2 Cycle oils:
Stihl and Husqvarna make really awful oils that make tons of carbon/cokeing that kills engines. Even their synthetics don't show great improvement with this either. And who in their right mind would ever try 'bio-degradeable' oils - of course it toasted your engine!!!... Let this be a lesson to you, duhhh.
Go and buy 2 cycle marine oils or 2 cycle motorcycle oils. Stay far away from the OEM garbage. I'm running the cheaper Pennzoil
It's $22-24/gal at Wally world and I'm running it a tad richer at just shy of 40:1 (42-45ish)
Guess what, no coking! Clean and shiny motor interior and no plugged up muffler.
As to a saw, I'm using a MS 290 20" Farmboss with a ported muffler. A bit more heavy than some of the more modern saws, but if I want, I can drop a 2mm larger cylinder kit into to and make it a MS360... See "The Duke" for chainsaw parts and mod kits. If money was less of an option then a MS260 series is lighter but pricey.
I agree that modern EPA regs have not done much good for saws. So look on Marketplace or eBay and see if you can get a lightly used older model.
Oh yah chaps and a helmet with a visor will keep your body parts in good repair. Always wear them!
Finally get a Hot-Stick or similar - it can save your life.
   / Best and worst chainsaw? #270
2 Cycle oils:
Go and buy 2 cycle marine oils or 2 cycle motorcycle oils. Stay far away from the OEM garbage. I'm running the cheaper PennzoilView attachment 1664133
Although some oil bottles say it's okay, Marine 2-cycle oil (TCW rating et al.) is not recommended for every air-cooled engine and certainly not for prolonged use. The additives in marine oils and air-cooled oils are often different because air-cooled engines tend to run hotter. You may not see carbon in the P&C, but it can be harder on the bearings over time.
There are also special air-cooled engines that benefit from specific 2-cycle oils. The Stihl 4-Mix engine (on many pole saws, string trimmers, and combination equipment) uses 2-cycle mix, but it also has valves that don't like most mixes other than properly mixed Sthil Ultra.
   / Best and worst chainsaw? #271
The absolute worse saw that I ever had was a Jonsereds 2045 which I bought for brushing boundary lines. That saw had to have made on a Monday, March 18 by an Irishman who's girlfriend left him on Saturday after breaking his bottle over his head. It's been a long time so I don't remember everything but I was constantly running to the shop. It was the time period spell when the muffler bolts wouldn't stay in, and those were about 11 bucks a piece. One day I rode my snowsled about 8 miles into the woods, snowshoed another mile and started doing a line. I was almost done when the sprocket separated from the clutch. I took it back and they said " I ain't never seen one break like that before." It was under warranty but still cost me a day. Luckily I had my trusty 254 Husky for backup
I finally sold the Jonsereds back to them; I was spending more time running to the shop than working.
   / Best and worst chainsaw? #273
Used marine 2 cycle for a decade Esp. when I owned the Ranger. Merc. Xr2. my guess it was the 2cyl. injected oiler went bad. The 150 had a broken piston so rebuilt it with a 175 Block bored and fiberglass valves. It hurt some feeling that's for sure thinking it was a 150 we left on the motor. It was seriously fast!! William Pain Pro Golf tour was the Prev. registered owner come to find out. Was nice.
That time of the Yr. here and burning is banned soon. Leaves and dry which is normal. I've always used a top end 2Cyl. oil. to many yard tools that are 2cyl. and have a bunch of problems Esp. notorious fuel problems. Chain saws sit for months summer and opposite with typical yard tools in the winter. End of the Yr. and I know there be sitting not being used I drain the gas.
The saws started right up and know how many pulls before you hear them hit! Husky 55 rancher I was wrong on a earlier prev. reply. I was thinking 1995 but looking at the Ser,# 5-29-00 Then it hit me why I was thinking it was a 95 era. model. I had to replace a Craftsman Sears store bought saw. I wasn't going to bother repairing it! Again...........................
   / Best and worst chainsaw? #274
I will start cutting firewood in the coming months which made me wonder, "what's my best and worst chainsaw?" I'm not extremely picky on brands but my experience with Echo is mixed and is limited to one model with Stihl. Aside from a basic homeowner, inexpensive poulan I've had 3 chainsaws.
My first "farm/commercial" grade purchase was the echo cs590 "timberwolf." Bought it bout 9 years ago (?). My favorite saw. 20" bar and cuts everything I've thrown at it. I've cut firewood: we heat our home with a Lopi wood stove. I've trimmed trees and cleared well over 1,000 cedar off of 70 acres. This saw is my favorite. It's a bit heavy for trimming and clearing cedars.
I wanted a lighter saw so, I stuck with Echo and bought the 4510 with an 18" bar. This saw never ran right. Finicky bout idling. I struggled with it for a few months. My dealer (who is great) tweaked it. Ran a bit better. I even started buying the echo premix fuel. I've always used premix but upgraded to echo's red "something." Somehow, that saw burned up and I threw it away after less than a year. The dealer said water somehow got in the fuel. I'm not sure how that could have happened. Regardless, I never liked the saw so I didn't press it.
I then picked up the Stihl ms250 with an 18" bar. This is a great saw. Lighter than the echo. And, starts a bit easier. But, it doesn't cut as efficient. I use both saws and appreciate them. The cs590 remains my favorite. It just cuts so dang fast and sometimes the weight works for me. Even when I'm sawing cedars horizontal the speed may offset the weight.
I do want a new saw. I'm thinking about a new cs590. What's your experience for best all around saw. By all around, I mean firewood and property mtnce (clearing cedar, fenceline cleaning, even cutting brush and underbrush).
I avoid anything with "Stihl" printed on it like the plague. The most over-rated, ****tiest, expensive paperweights ever made. Just wait until you need to cut a tree on a 15 degree morning. I hope you're in good shape, because going to the gym would be easier than trying to start a POS Stihl power tool. We've got a Stihl "Farm Boss" we bought new several years ago and an old Dolmar saw we've had for decades and an electric 48v Kobalt saw with a 12" bar. The Stihl is the last one of the 3 I'll pick up to do a job with.
   / Best and worst chainsaw? #275
As I mentioned earlier, check out the Husqvarna Poweraxe 350i electric. It has a big honcho battery, and it never fails to start if your battery is charged. It cares not whether gasoline has ethanol in it or not. It runs smoothly and with an 18” bar it will handle almost anything you will need it to do. You won’t need any hearing protection, as its decibel output is far below that of its gasoline counterparts. I use it on my ranch it the Texas Hill Country and it is a great saw for my purposes, which are many, varied and moderately demanding.
I used to feel like anyone who embraced an electric saw was some commie pinko leftist Greta Thunberg type. My buddies were the same way, and chided me for buying an electric. I had them come up to the ranch one weekend to help me clear a fence line and told them to use my new saw. One guy had his old gas saw and another started out using the electric while I was on the tractor using the FEL and grapple to remove what they cut to a burn pile. After lunch the guy using my electric told the one using the gas one to give the electric a try. He did, and after dinner that night I asked him his opinion of it. He smiled, as he was the biggest critic of me going “over to the other side” and said, “I think I have to have one of those.”
   / Best and worst chainsaw? #276
I stayed away from Stihl. The saws I've seen didn't seem last without problems. The Echo I went light weight and small. No problems with any Hard parts that I can see so far. The plastic was understandable price wise. This showed up and would be nice if it does work. Yeah or Neah?
   / Best and worst chainsaw? #277
You are sharping the wrong side of the tooth, I bet it would work once or twice then you are back to sharping the tooth correctly from the inside. YMMV
   / Best and worst chainsaw? #278
Neah, looks like it just files down the tops of the teeth
   / Best and worst chainsaw? #279
I didn't watch the entire video because of the damned racket they had playing,
however I seem to recall that they sold a chain just for that type of sharpener.
Still pretty much a junky nik nack .
   / Best and worst chainsaw? #280
2 Cycle oils:
Actually running marine oil designed to be water cooled in a air cooled engine is terrible advice. Terrible.
207277 (A52708)
207277 (A52708)
2016 VERMEER PD10 PILE DRIVER (A60429)
2016 VERMEER PD10...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
iDrive TDS-2010H...
