bent tie rod
/ bent tie rod #41
</font><font color="blue" class="small">( His dealer has the part, no problem!
I have a cow catcher on my CK, it's called a FEL. )</font>
I agree. if you are going into un-charted territory,keep the FEL down. And that's coming from the bent tie rod pioneer! /forums/images/graemlins/wink.gif
/ bent tie rod #42
Yes, I agree. Learned my lesson, the hard way /forums/images/graemlins/crazy.gif.
/ bent tie rod #43
I thought we were talking about one part??? And yes, I would say there was some venting going on, (that's fine). My point was that I don't believe it is fair to judge because of availability on ONE part. I guess time will tell the real story.
Have a nice weekend! /forums/images/graemlins/cool.gif
/ bent tie rod
true........but the part is not some obscure left handed axle housing gear pin actuator. By the direction of this thread I'm glad I was able to repair bent tie rod!!!!!!!!!!!!!! /forums/images/graemlins/wink.gif
/ bent tie rod #45
</font><font color="blue" class="small">( I don't believe it is fair to judge because of availability on ONE part.
true........but the part is not some obscure left handed axle housing gear pin actuator. By the direction of this thread I'm glad I was able to repair bent tie rod!!!!!!!!!!!!!! /forums/images/graemlins/wink.gif )</font>
Just an observation here but it is not ONE part. Just on this forum there are 6 or 7 tractors with the SAME bent part. Now realizing that TBN users are a small minority of tractor owners, it seems reasonable to believe that there are more bent tie rods than just these 6 or 7 and it also seems reasonable to believe that it is a fairly common problem for this model given the reports here.
/ bent tie rod #46
I think the common problem is hitting objects sticking up higher than the tie rod. It would be nice if it were higher up, I moved all my Jeep steering gear up for that reason.
/ bent tie rod #47
Gee...Kinda new here...just took delivery of my Ck20 TLB...glad I got that one rather then the CK30...not sure I really want to worry about getting a left handed axle housing gear pin actuator
Can anyone tell me what that does and if I really need to know?
/ bent tie rod #48
Sammi, thanks for making me smile this morning.
To the others.....When I said one part, I meant one piece of the tractor. If there are 6 or 7 bent rods, to me that is one part on 6 or 7 different tractors. This thread is about one part of the tractor and it's unavailability, (or did I miss something)?
Oh well, looking forward to cuuting and hauling some firewood this morning while it's cool. I'll keep an eye out for stumps too. /forums/images/graemlins/wink.gif
/ bent tie rod
right, one part, multiple damaged machines but one part. I'm glad you agree. The left handed axle housing gear pin actuator is made up. /forums/images/graemlins/grin.gif
/ bent tie rod #51
I received my replacement tie rod yesterday. /forums/images/graemlins/laugh.gif Ordered on 9/8 received on 9/19. Not too bad for a back ordered part. /forums/images/graemlins/smirk.gif
/ bent tie rod #52
Hey, I bent my left handed axle housing gear pin actuator last week! I switched it with an extra right handed torque extender pin and everything was fine. /forums/images/graemlins/tongue.gif
The way I use my machine I might be better off ordering a tie rod now...its only a matter of time...
/ bent tie rod
tell us how you did that? left and right are not interchangeable unless you.................swapped ends???!!!
I thnk it was said best that if the tie rod is bent in the future, just adjust the toe in and keep on truckin'. The front wheels don't know the tie rod is bent. There is a good thing about this that if you do bend the tie rod, put the bent area towards the motor so it doesn't hang down so low............hhhhmmm /forums/images/graemlins/smirk.gif
/ bent tie rod #54
Ok ok I give up...this must be important..can someone please tell me what the left handed axle housing gear pin actuator is and what it's used for?
All these people breakin/bending stuff...don't want that to happen to m Ck20hst....
Does my ck even have one of these?
/ bent tie rod #55
</font><font color="blue" class="small">( Ok ok I give up...this must be important..can someone please tell me what the left handed axle housing gear pin actuator is and what it's used for?
Does my ck even have one of these? )</font>
No, and neither does theirs..
/ bent tie rod #56
Wheww...Thanks Dk for letting me know...one less thing to worry about....um..what about the right handed torque extender pin?
I need some rest.. my head hurts.. /forums/images/graemlins/smile.gif
/ bent tie rod #57
And to make matter worse they are all runnning low on Blinker fluid and as AJ would say "the torque converter's runnnin' low on torque"... /forums/images/graemlins/grin.gif
Sammi>> not trying to bust yer chops here.. we all have days like that, but you brought tears to my eyes with all that.. have a good one my friend... /forums/images/graemlins/wink.gif
/ bent tie rod #59
I wish I had a picture of the link that a customer bent in half on a 3054. The steel bent into a big "U" before it snapped the tierod threads. bent it str8 and borrowed my favorite Lancaster natives welder and weld the end back on, so I could get it loaded on the truck.
KO
2004 JOHN DEERE 304H WHEEL LOADER (A65056)
2004 JOHN DEERE...
1999 INTERNATIONAL 2674 T/A DUMP TRUCK (A67714)
1999 INTERNATIONAL...
2024 Kubota L47 T.L.B. 94HRS FOR SALE loaded w/options & $17K off new at $63,900!
2024 Kubota L47...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2017 CATERPILLAR 980M WHEEL LOADER (A65056)
2017 CATERPILLAR...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2022 Mack Anthem...
