Bent Loader Bucket
/ Bent Loader Bucket #1
gilbertmsg
Disputanta, VA
2007 Kioti CK20
I added a thumb to my bucket. Went for a test and bent the top of my bucket about 2-3 inches up. Tried attaching a chain and using bucket to pull back down with no luck. Just looking for some ideas before taking to welding shop and having entire top cut and replaced.
Eddie
/ Bent Loader Bucket #2
May need heat and a hydraulic press to put back in place. The upper edge of a bucket is not very strong as you discovered. It will need to be reinforces quite a bit to support a thumb. I reinforce all my buckets and I don't use a thumb. Eventually they all bend anyways.
andy
/ Bent Loader Bucket #3
Heavy duty "C" clamps and sturdy angle should straighten that out.
Tighten the clamps to pull the bend inwards with an occasional wack with a sledge hammer to coax the bend back.
You could also cut the flange before bending back and once straight re-enforce with a welded in place angle/doubler.
10ft S/A Cargo Trailer (A66738)
10ft S/A Cargo...
GAYLEAN  130BBL VACUUM TRAILER (A67714)
GAYLEAN 130BBL...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2027 . . (A67714)
2027 . . (A67714)
2017 KENWORTH T880 (A67714)
2017 KENWORTH T880...
Set of 2 Unused ST205/75R15 Radial Trailer Tires (A66734)
Set of 2 Unused...
